The Apollo MTM cabinet is the perfect overall size that I'm looking for, however the cost is a bit more than I was looking to spend.
My thoughts are to buy the Apollo MT kit, but build it into a 1 cu ft cabinet with about the same dimensions as the MTM version, tuned to about 35 hz (2" Precision Port at ~5.5" long). Given the 7" Anarchy specs/capabilities, is this a good idea or is that too much volume for the one woofer? Probably of important note, is that I will not run it full range at high volume ever. When I'm looking to crank, I will employ a separate sub crossed at 50hz. However for lower level listening later in the evening, my hope is that this design would be fine without the sub yet still provide noticeable bass.
