In preparation for taking measurements for this build, I decided to take a reference measurement from my current speakers - a very well regarded commercial floorstanding speaker. I was surprised to see the significant drop off after 10khz. Is this surprising to anyone else, or am I perhaps doing something wrong in my measurement setup?
Cheers!
Joe
Thoughts on this combo - BZ Tweeter and Dayton Epique
- Likes 1
I bought one of those bits. The only reason masses call them oops bits is they don't see the reason it was done after. Sometimes order of operation dictates that this has to be done after the assembly so you don't blow through an edge or thinner material. Sometimes you can't cut driver rebates until after the cabinet is assembled.
- Likes 1
Originally posted by jml View Post... otherwise known as "Oops" ...
Originally posted by jml View PostThat’s a smart solution. I looked to see if they made an undercut 45 degree bevel bit with a top bearing, and I was surprised to see that it doesn’t look like they do.
Originally posted by davidroberts View PostA top bearing can be added to any bit with a substantial shaft length. Check https://www.mlcswoodworking.com/ and I bet you can find something.
Originally posted by DrewsBrews View PostI've used an inverted cone type slotting bit for this purpose, since I don't have a dovetail bit. I just extended the shank down more than usual, using the shank as the bearing surface. Though start to run out of shank for much more than 3/4" material. Probably not the best/safest idea, but it has worked so far.
- Likes 1
Originally posted by a4eaudio View PostIf you decide that you really want to do something still, use a rasp. It would be tedious but it will work.
"Slot and undercut router bits, otherwise known as "Oops" bits are used to undercut a part that is attached to another part. Typically this machining operation would be done before installation with the surface to be machined facing up. If it's too late and the part is already attached - 'Oops!'"
With that said, I do not plan to remove additional material from the inner baffle.
Cheers!
Joe
It's not easily visible in the photos, but I did round over all the internal edges on the MDF; however, I did not go nearly as aggressive as these samples - mine is more an example A situation. I think I'm too far into the project to start over now HAHA!
You should have done this. I'm surprised that Mr. Wolf didn't tell you.
- Likes 1
Sanded down 120, 180, 220, 320, 400. It only took about 30 minutes altogether and was WELL worth the extra effort.
The hardwood and veneer match even better now, but they still clearly have 2 different materials. I am debating about doing the black aluminum top plate I was planning vs topping it with more hardwood. I’m afraid the black might be too much… a 2 tone speaker is cool a 3 tone speaker feels a bit busy.
cheers!
Joe
- Likes 1
