If you have an immediate customer service issue, please visit us at Parts Express
The MAIN thing about DVCs (AFA box size and extension are concerned) is that IF you used only a single coil, "Q"s (Qes, and therefore Qts) nearly double.
Since Q affects both Vb/Cb AND F3, a single coil will typically double the required box size (but F3 should also drop, substantially). - sgc
You can even tailor a DVC's "Q" by driving one coil and using resistance across the other (if you had to fit a certain driver into a certain box, for instance).
damn it.....you guys have made sense..That W130x 2x4 build is a dual, im using the series crossover, but dont know how i put it in to WiniSD.....didnt think of that.
