HiFiCompass measurements - How to interpret and what matters?
  • #16
    Originally posted by devnull View Post
    Should a driver that costs that much need that many crossover parts to make it usable?
    Originally posted by fpitas View Post
    If you like what hard-cone drivers do, you're stuck with that sort of thing. Obviously, that's a matter of taste. I like the "see-through" clarity I get from my W18s.
    Of course, there's always the paper cone Purifi model for those that can't be bothered with added filter complexity. I hear its just okay though, so might as well go the extra mile for the Aluminum version
    • #17
      I notched the ultrasonic resonance in my EMP build using the 27TAC/GB.
      There also Is interesting info in the Purifi doc, about notch filters, that apparently I've been doing a lot of. Using the dual notch arrangement to both short out and attenuate a breakup range is something I do a lot, but the reduced HD is both good news and results I was unaware of.
      • #18
        The only real gripe I have with the article is the use of terminology. What they describe as a series notch, I would describe as a parallel notch, because the components are in parallel (but the network is in series with the driver). What they describe as a parallel notch filter, I would describe as a series notch filter, because the components are in series (but the network is in parallel with the driver). The description of series/parallel notch filters in this article is backwards from common electrical conventions for this terminology.
        • #19
          A series notch is of series components placed across the driver, at least this is convention.
          A parallel notch are parallel components placed in series with driver. This is normal convention.
          i may have misread the article, but did not come to the same conclusions.
          • #20
            Not that www.diyaudioandvideo.com/ is authoritative, but they define them as below. When I was first trying to understand notch filters for my first speaker, I did come across a lack of consistency in terminology on the web.
            Parallel filter...
            and series filter...
            • #21
              Yes, that's the correct terminology.
