Hi George,
The ”outrigger” concept may require some investigation.
For a very simple reason.
The outrigger has the potential to take significant amount of (loudspeaker + rig itself) weight off the turntable. This would almost double the available load spinning capacity of the turntable.
The outrigger does not have to be placed at the end of the loudspeaker. It only needs to stand far enough from the turntable to prevent the loudspeaker from tipping over – so just past the long wall’s half-way point. Assuming, that the outrigger is rigid enough, this would rest almost the whole weight of the loudspeaker on the outrigger. The turntable role would be to driver the outrigger.
Perhaps, the wheels of the outrigger may need to be replaced by just a single wheel on a swivel, and the wheel would have to be attached to the turntable by a rigid rod, or some other rigid means, so that the outrigger does not tip forward/backwards.
Even for the horizontal polar measurements ( loudspeaker placed in a normal vertical position), you could attach to the turntable (behind the speaker), a small outrigger with a platform, to support the loudspeaker’s weight at the back. This way, no need for the “curtain rod”.
Anyway, does this make sense to anybody?.
Best Regards,
Bohdan
Best Regards,
Bohdan
