If the box/baffle simulation is accurate, it looks like there's even less change than I thought there'd be.
If you didn't already know, raw speakers are usually professionally measured while set on a large (practically infinite) baffle, while the much smaller real-world baffles we all use cause a 3-6db drop in bass and low-mids and usually a slight 1-3db bump in the higher mids. Flip that upsidedown and becomes a handy "target" you can use in simulations if you only have the manufacturer measurements of the drivers on an infinite baffle.
But it looks like they all line-up very similarly:
I think they're all within about 1-2db of eachother.
The different baffle shapes/sizes and driver positions also changes the off-axis baffle responses, which I'm also guessing might be small-ish changes in this situation but still worth mentioning in case I'm totally wrong.?
