Bill,
Firstly I note that the upper crossover frequency doesn't really matter to me. I could cross it at roughly 2k with an 18db/Octave crossover and genuinely believe the tweeter would do quite well. In this case, the mids crossing over at 2k would do the job. The sb26adc can be crossed really low, so anywhere from 1700+ should do the trick (depending on crossover slope obviously). I keep referring to thermal power ratings and that's because I like playing it safe. I don't want to blow a driver, but I am aware it varies on a LOT of things like temperature and frequency band and voltage.
As far as separate subs go, you've mentioned a few times that the subwoofer being on the speaker itself isn't ideal in most cases which I find very intriguing. Obviously it varies from room to room, but what would be the rule of thumb for placing subwoofers? (Assuming I split it to be a 2 way + sub)
Andy,
thank you for the very interesting read. I find it intriguing that the resonance (whatever the part that improved with decoupling is) is located at roughly 400hz on this experiment. Certainly this is an indication that a midrange would be better to de-couple than a subwoofer but I should probably do some more independent research to confirm this. The article I had read is at this link:
https://audioxpress.com/article/spea...ced-vibrations
If I have misrepresented something from this article, please tell me as I didn't mean to.
As for the gaskets/well nuts and etc: I will have to look into that. They seem useful.
Andy,
