Introducing: The Pit Vipers (Ooh Yeah!!!)
  • Hey all, long time listener...first time caller.
    Spring of '21 I built a pair of Classix II from a knockdown kit from PE (https://www.parts-express.com/Classi...112?quantity=2) with the purpose of using them in my office to play LPs. They turned out great and I enjoy listening to them for hours while I work.
    Well, my wife wants to use my setup to play her records but wants to listen to them all over the house. The Classix II perform pretty well but we want..... MORE. I go and check the latest speaker designs and what else enters the ring but the PIT VIPERS, YEAAA. I like big woofers and I cannot lie, sorry not sorry.
    Annnyway, looking over Paul's notes he said he might've increased the thickness of the front panel and add more bracing. Before I go out to garage and start cuttin' up some mdf I wanted someone to go over my changes:
    • I'll be gluing 1/2" MDF to 3/4" MDF to the front and back
    • I added 1" of depth to regain the volume lost by above
    • Instead of window pane style bracing I will be using what I'll call diamond or diagonal bracing. Diagnoals keep things square.
    • I moved the woofer lower and readjusted the mids and tweeters. I plan on putting the speakers on the foam risers that have a 5-10 degree angle so the lows dont hit the floor as much and the tweeters are a bit closer to walking ear level.
    Should I add a second diagonal brace below the woofer? I'm thinking its not necessary with the other changes I've made.
    Thanks in advance!
    John​
    • djg
      djg commented
      Editing a comment
      The point of a thick baffle is to have sufficient thickness remaining when you cut rebates for the drivers, and to maintain strength in a panel with big holes. 1/2" more would be good, I think. I wouldn't bother with the back panel, especially if you add two more braces, one between the woofer and the ports, and one between the midrange and the tweeter. One builder IIRC, has gone with what I tagged as "hashtag" braces. I wouldn't do diagonal bracing, but that's based on "feelings", not any data. I like windowpane bracing, but lots of builders whom I respect say the only important parts of a brace tie the opposing sides together in the "middle" of the panels. Bracing is second only to capacitors for "discussions".
    • djg
      djg commented
      Editing a comment
      And I wouldn't cut the speaker holes and rebates until I had the drivers in hand. And the port holes too.
    • eisenhowerj
      eisenhowerj commented
      Editing a comment
      Yep, I have the components and on my doc it says the specs were pulled from PE but the builder should double check. The image compression is making that hard to read. This is version 0001 so I'm not going to share the pdf until I can say they're optimal.
      The "discussions" out there are very lengthy and to be fair, the anatomy/build/age of everyone's ear is different so I take some judgments with a grain of salt. I could use 1/2" of dampening on the back wall in place of the extra MDF I was adding there. I don't think I want to add too much bracing that is attached to the front panel, in theory...to reduce the energy transferred to the back and sides. The woofer is 10lbs (4.5Kg) so the bracing I do have and the extra 1/2" on the front panel will help support that.
      Thank you for your responses, they are appreciated.
  • Here's how I did my last project, a smaller 3 way. I would say it has minimal bracing. My bracing is all stick built as I do not have a CNC. Just for ideas, not a recommendation.
    • Hey guys. I'm back.
      Well, one bathroom remodeling eventually turned into 2 bathroom remodeling and another complete bathroom addition in the basement.
      Now that that's out of the way..... I'm planning to get back to finishing these soon before the wife comes up with something else that " we " need to do !!!
      • 3 done
        • Nice work, welcome back.
          • Thanks D
            • I've joined the pit viper party, got all the xover parts and the mid and tweeter. I'll grab the woofers at a later date. Plan is to do them kinda troels graveson style with vertical ply baffle inlays and such. Got a new router and eager to source some nice wood and get started.
              • Hey, quick check in. First coat of enamel on and testing fitment of the drivers!
                • Oh shoot, i got 20awg inductors rather than the 16-18awg, should I go for the awg specific in the plans or will these work?
                  • Anyone? Bueller?
                    • Originally posted by joshshetter View Post
                      I think 20 awg will be fine. The big coil on the woofer would matter the most (because of DCR), but it's iron core, so DCR is minimal there anyway.
                      Twitter: @undefinition1
                      • I was ready to look into building the Pit Vipers, but since I have the Vortex 15 done, I'm thinking mixing monitors, if I decide to build something else. If anyone reasonably close to Indianapolis gets a pair up and running, I would love to get the opportunity to hear them. Glenn.
                        • It's approaching one year for this design, and I haven't seen a completed project. Come on guys.
                          • eisenhowerj
                            Editing a comment
                            I'm almost done depending on if I cover it with clear coat or not. See post Jubilees I'm not sure what the photo dump etiquette is on this forum but I have a few pics from before glue up.
                          • eisenhowerj
                            Editing a comment
                            I guess I have some things to learn about this forum. It gives me all kinds of errors when I try to post, then an hour later it shows up. :shrug: On post "two eighteen" there is a picture that shows up in one browser but not the other.
                          • djg
                            djg commented
                            Editing a comment
                            I look forward to your pics. The forum has been wonky for months. There is a thread to complain if you so wish.
                        • Originally posted by djg View Post
                          Hey now stuffs spensive, Once I get wood mine will be up and running pretty quick. I'm of cours accepting donations for the wood ;)
                          Thank you Paul!​
                          • djg
                            djg commented
                            Editing a comment
                            Honestly, I was tempted to build these as a homage to my stolen JBL L100Ts. But, I have no place for them, and I would have needed a whole bunch of walnut veneer. I built JR's new 8" 3 way instead.
                        • And what happened to 9sheng? He hasn't posted since January. Did he let his social credit score slip?
