Introducing: The Pit Vipers (Ooh Yeah!!!)
Hey. Yeah. That explained it much better than I did. I could picture it I'm my head, but had trouble conveying the idea.
I'd be hesitant to just wedge them in. A modified version of the above...use 4 to 6 one-inch dowels. Using a 1" forstner bit drill a hole about 1/4" deep into the back side of the front baffle, glue (clamp if possible) - they are now a permanent part of the baffle. Make them to 1/32" to 1/16" of the cabinet depth and screw them in from the back.
Originally posted by Paul Carmody View PostDespite adding internal bracing, I think the one panel I've neglected is the front baffle.
In the past I used to just default to double-thick baffle with woofers 8" or larger. But with this particular design I have been making a conscious effort to keep weight down as much as possible. So far, it's a plain rectangular prism, about 70-ish Liters internal volume, using .75" stock all around; about as simple as I can make it.
But that baffle has a lot of holes in it; and I feel like the 12" woofer is playing it like a piano sound board. Don't get me wrong, I think what I've got here so far sounds pretty darn good and isn't ringing nearly as bad as it used to. But I can't help but think that I won't really know if I've done everything I could, unless I dampen or reinforce the baffle somehow.
Even if the front baffle is removable, just attach the strips to the insude of it and let them wedge against the rear wall. Maybe cut them 1/8" or so longer than the actual distance.
Put some gasket tape or weatherstripping between the baffle frame and baffle to help decouple and seal them as well.
- Likes 1
You're correct. I was surprised how much it helped cut down on the vibrations. When you think about it, it's essentially battens that are 1/2 glued and 1/2 mechanically fixed.
The framing for the removable baffle should help with cabinet rigidity a little
Correct. And I'm really happy with it in this application. Also, I just noticed that it's seems to be another casualty of slow supply chain. Hopefully more come in stock sooner than later!
I just dont know how many screws ( bolts?) to use or proper spacing to keep it from leaking or vibrating.
- Likes 1
Originally posted by bassman_soundking View Post
It looks like the Peerless D27TG35-06
- Likes 1
On the subject of bracing
As I mentioned earlier, this cabinet definitely needs some bracing. My go-to is usually scraps of MDF, 2-3 inches wide, jammed/glued between walls. So that's basically what I did here.
I tried to tie in the back walls and the top as well. Could this be improved? Yes! In fact, I invite anyone out there who builds this design to experiment with different ways to give the cabinet some rigidity and raise the resonant frequency. (Or, if you're just good at CAD and want to draw something, I'd be interested to see that, too)
Here's my basic process for adding bracing:
1. I knock on the cabinet wall with my knuckles
2. Then I wedge the piece of MDF in place
3. I knock again on the cabinet and listen for the pitch to go up.
4. If I like the spot, I apply some glue on either side and wedge it back in
5. sometimes I'll shoot a brad nail in from the outside to hold it in place while the glue dries--although that takes some pretty good aim.
Also, you probably also notice a strip of hardwood around the inner perimeter of the front edge of the cabinet--that's for having something to screw the baffle into. Oak on the top + bottom, and maple on the sides, if anyone cares. Doing a removable baffle is actually a lot of extra steps, and somewhat of a hassle, but it's worth it in the long run as I can keep cutting new baffles to experiment with different driver combos.
- Likes 4
This looks like something the DIY community could use! A modern take on the monkey coffin that's not $3K per speaker. Reignite the dorm/garage party speaker.
What did you do for ports? 2x 2" or 2.5"?
Now you have me thinking - I have the BC25TG15-04 here from when I built your classix 2.5 years ago, perhaps I could follow along with the DSA315-8's I have here and get some of those new SB12's mentioned earlier and see what I can come up with.
- Likes 1
