Introducing: The Pit Vipers (Ooh Yeah!!!)
I don't mind giving advice but this is Paul C.'s design. Read back in this thread and follow his advice on what's an acceptable substitute. I believe he clearly addressed this. He forgot more today than I know about XO design. I just have experience following plans, schematics and instructions. Good luck.Last edited by djg; 07-07-2022, 07:56 PM.
Thanks djg.
I guess I'll go with this and the 5.0 mH air core inductor then.
It should work out fine then correct ?
Yes. NPEs are a cost saving measure. All of the NPEs can be poly caps if you wish. Large poly caps get expensive.
@Paul Carmody I would like to confirm, how thick are the cabinet boards you are using?
I feel like 18mm will look thin.
The second is how much filling is needed inside the box? Is it possible to cover the whole thing?
Afternoon Paul,
I have to ask...
How does the Pit Viper compare to the Tarkus?
Seems like it would be similar in voice.
I am thinking of using my Tarkus for surrounds and the Pit Vipers for my mains.
What are your thoughts?
I can't wait to see these and hear what you think. I've been dragging my feet on a pair of Vortex15 speakers, but I saw this and really love the design and the price range. Summer has been very busy, and it's motorcycle season, so here's to living vicariously! Glenn.
Yes, good plan.
And that would make it easier to biamp your pit vipers with this terminal cup.
This appears from the part number to be the same as what is back-ordered on PE.
Can anyone verify ?1 Photo
Originally posted by djg View PostI would make 3 separate crossover boards given the room available, one for each driver. Leads to less confusion if you're new to crossovers. No condescension, I would do 3 boards myself. More coil separation possible.
I guess I could mount the woofer board on the bottom of the enclosure and the mid and tweeter boards on the window pane braces closest to those drivers.
Does that sound logical ?
- Likes 1
Paul Carmody
Hi again. Well, I've gotten in everything except the L4 inductor and a couple other odds and ends for these.
Would it be possible for you to post a picture of your crossover board layout. I'm wanting to organize this correctly.
Thanks again for everything you do for us !
Any one of those 3 is totally fine.
As I said earlier, I'm gonna go ahead and say it's OK to use an air core 5 mH coil, even if its DCR is slightly above 1. It'll work out, and you'll like it :-)
FWIW, I wouldn't hesitate to use No. 1. There's nothing wrong IMO with using a steel laminate inductor regarding sound quality, especially in a woofer crossover, and it's sure less expensive. In my Post #101 in this thread, the response for the modeling I did of the Pit Vipers had 0.5 ohms added in series with the woofer to represent the resistance of a series crossover inductor, which is almost identical to the d.c. resistance for your No. 1 inductor candidate. Nevertheless, the Pit Vipers is Paul C's design, not mine.
Paul
