Originally posted by JRT
View Post
Music lives in the midrange
found a pair in Canada new in box 1880.00
Not the ATC SM75-150S, but there is a new pair of SM75-150 (non-S) listed for sale at canukaudiomart for (CAD)$1880. For that many Loonies, you could buy a new pair of KEF LS50 Meta and cannibalize those for the coaxials, or just add bass-bins under suitably modified units. Those KEF coaxials might be the better choice for a domestic application not needing the high maximum SPL output or increased signal voltage sensitivity.Last edited by JRT; 05-19-2022, 06:35 PM.
Apparently a 3.3” midrange is coming from Scan-Speak.
D8404/552000
was at Troel’s website before shortly taken down?
You know you’re an influencer when you get early access/samples and everyone gets excited.
bye bye wallet.
- 1 like
I saw that briefly, it was part of the Elipticor range so will probably rival the Bliesma T74B 3” Beryllium dome for price. The Troels design was a 4 way using all Ellipticor drivers so was pretty top end 1+3.3+8+15 layout iirc. Looks like the info is back up including a spec sheet for the mid dome. http://www.troelsgravesen.dk/Ellipticor-A50-II.htm here https://www.scan-speak.dk/product/d8404-552000/
Originally posted by donc View Posti dont remember Jeff liking the AE TD6M , seems like there was a hard to work with dip or something ,others found the TD6M to have it also .he chose the Dayton PM180 over it on a design for me ,case by case could apply .the ATC dome he did like , its just hard to come by .seems like its available from the guys in Canada every once in a while .they have one that looks like the ATC but its made by Volt .its expensive as is the ATC ,not sure about performance .
donc
- 1 like
The CA Prestige drivers are older tech and have breakup that needs addressed. A lot of times, the xover has to be pretty low to help manage this. How far is the breakup suppressed in your Sim? As long as it is 1800 or higher, the tweeter won't care.
Originally posted by Wolf View PostThe CA Prestige drivers are older tech and have breakup that needs addressed. A lot of times, the xover has to be pretty low to help manage this. How far is the breakup suppressed in your Sim? As long as it is 1800 or higher, the tweeter won't care.
Question, are those traced manufacturer's curves, and if they are, did you adapt them to your proposed baffle and placements?
What I'm seeing looks like it was way too easy.
EDIT: I see now it's the 4.5". I thought you had the 5.25". Breakup will be higher in freq and better manageable, but Sd is small and mating to a 10/12 might prove taxing on a driver that small at that frequency. 400-500 would be better for a 4.5". If you want 250Hz, go to the 5.25".
I still think the xover looks way too easy.
Hope this helps,
Wolf yes thats the smaller version. I am attaching the next larger one (H1262) Correct that is traced. I am using 2nd order XO. If you think I should move to the next larger dia (H1217 7inch) or even the Tymphany driver 830991 let me know
Your sim is not indicative without adapting the files to the baffle design. I feel the files need to be adapted to your baffle, then simulated. This is a wash....
Yes you'll need the larger midbass.
Originally posted by Wolf View PostYour sim is not indicative without adapting the files to the baffle design. I feel the files need to be adapted to your baffle, then simulated. This is a wash....
RM can do it.
Originally posted by jimbones View PostI've decided that I want to try the best sounding midrange I can find.Originally posted by jimbones View PostOne thing about the mid priced drivers it allows you to experiment without going broke.Originally posted by PWR RYD View PostDon't rule out the Dayton PM180 drivers. They don't do bass but sound fantastic as a midrange IMHO.Originally posted by donc View Postbuy the PM180's ,cut some slits in the cone, can't go wrong
Here is a link to the slit-cone modification thread:
https://techtalk.parts-express.com/f...n-your-pm180-8
Here is a link to PE's marketing webpage for the PM180 driver:
Here is a link to the 3D printed waveguide thread:
https://techtalk.parts-express.com/f...ed-waveguides/
Last edited by JRT; 05-21-2022, 07:23 AM."Our Nation’s interests are best served by fostering a peaceful global system comprised
