Originally posted by jimbones
View Post
Jims 3 way speaker build
OK Im back. I just wanted to spend a bit of time listening to them. I am not getting the impact of the low bass that I had expected from this setup. I will do a sweep and just to let you know the Lv is 10 inch and should be tuned to 33hz.. If someone can help me pinpoint why the low bass seems absent
Originally posted by jimbones View PostOK Im back. I just wanted to spend a bit of time listening to them. I am not getting the impact of the low bass that I had expected from this setup. I will do a sweep and just to let you know the Lv is 10 inch and should be tuned to 33hz.. If someone can help me pinpoint why the low bass seems absent
Are you using an AVR? Is there any chance that the speaker selection is set to small? Anyone fiddling with the tone controls, like kids?
Per my last post. I tried level matching your measurement results to what would be expected based on driver spec - tweeter and mid should both be playing around 89db based on specs and your woofer with full BSC will be down around 85db. Both mid and tweeter will require padding to balance the speaker.
Might be a slightly unorthodox approach to just level up your frds but the accuracy of your measurements is dubious so just trying to work with them as best as one logically can.
The link I sent you to measurement procedures which includes taking woofer and port nearfield, combining them accurately and merging them with far field is well worth the read and will give you a much better picture of what's happening with your bass performance. Of course you also need to measure the thing up off the floor but understand that's not possible so it's just a level of inaccuracy that has to be worked around.
Bottom line, without correctly padding down both tweeter and mid, these are going to sound thin and the bass performance will be subject to finding some sweet spot where room gain compensates for the lack of BSC.Constructions: Dayton+SB 2-Way v1 | Dayton+SB 2-Way v2 | Fabios (SB Monitors)
Refurbs: KLH 2 | Rega Ela Mk1
got ya. i am padding the mid and tweet and it is helping. i think i need to pad a bit more. i also checked with Madisound regarding the tuning and it wasn't so clear on their answers (16 inch vent, vs my 10.5 inch vent and shelving below 45hz) The ran a sim in Bass BoxPro.Either way they said I need to let the woofer break in as it has less than an hour on it..
A close mic measurement on the woofer will show you what the tuning frequency is! Very easy. Just don't stab the driver with the mic like I did last night! (No damage, just bumped it.)
On my speaker... I had it sounding good,but it needed padding like yours. Adding resistors fouled up everything. You will likely need to verify roll-offs, etc.
On the port tuning side of things - calculations are good for a ballpark starting point - and in some cases end up being spot on but in just as many cases need some fine tuning. Once you have the box with final stuffing etc then you can throw the formulas out and just focus on your measured results.
Woofer break-in etc will have no effect on the box tuning - box tuning is a relationship between the air volumes of box and port, independent of the woofer. Its how the box tuning affects the woofers performance that will change with driver break-in. This is where the near-field measurements for woofer and port, and the appropriately combined sum tell you if the tuning of the box is getting the right magnitude response from the woofer+port combination. If you see a peaked up sort of bass response, tuning is too high for that woofer. If you see a suppressed gradual rolloff and a higher f3 than expected (more like a sealed response), the tuning is too low for the woofer.Constructions: Dayton+SB 2-Way v1 | Dayton+SB 2-Way v2 | Fabios (SB Monitors)
i was about 1/4 to 1/2 inch from cone. I was flush with port opening. I did 2.5 msec gating. We also did other freq tests and it is fairly flat to about 60 then it drops and there is a shelf such that the output at 25hz is the same as 40 hz. there is little "weight" to the music.
I'm not sure, but I think:
Jeff Bagby's white paper and VituixCAD guide both recommend nearfield at about 1/4".
You need to run your nearfield measurements through a diffraction simulation to remove baffle step. Your farfield measurements would already reflect this, as they were measured in the actual cabinet on the actual baffle.
You do NOT need gating on nearfield (or at least it can be long, like 30 to 50 ms). You're a quarter of an inch away, no room reflections are making it to the microphone for quite a while relative to the primary signal.
all, Hold the phone! In prior posts I had asked about ports (proximity to cabinet etc and port length) Well I cut the port for one speaker and additional inch-1.5 inch so it gives me more room between the padded rear wall and the port. Today I was playing bass heavy material and in one speaker air was coming out of the port and on the other nothing. I am wondering it is being blocked. This coincidentally is the speaker I was making measurements on. I will go and cut the other port so the match and rerun the sweeps. Stay tuned (pun intended)
