Jims 3 way speaker build
question regarding vented alignment: Im thinking this is a SBB4 or SC4? Is that right? If not what alignment is this. (If I tune to 32hz it gets flatter still, so I am thinking it is a SC4)
Note to all: Previous individual threads addressed driver selection, optimal enclosure size and venting/tuning (70L), and midrange enclosure sizing. I am currently finalizing my cabinet drawings and anticipate having cabinets in July. Just wanted to give everyone an abridged version of where I am currently at. Thanks
Trying to figure out how to enable macros on my PCD. I usually compare my values to the auto calculate. Anyone know how to enable the macros? I tried several things but didnt work. I dont remember having this issue before....
The only reason I used 3.3k is because I have tried using the mid and tweet in a prototype set up and the tweeter sound better crossed over higher.(tried 2.2k didnt like it) Right now I have it at 3.3khz 3rd order. Now I wouldn't expect it to stay the same when I do the final build but I would expect it to be fairly close. The crossover will change im sure.
I would recommend using no offset for the mid-range and tweeters due to having better Imaging at the listening position and better off axis responses. This will also help with BSC on your wide baffle.
There is no reason to xover at 3.3kHz or 2.5kHz, unless the drivers lend well there. Even at 3.3k, you should not need to overlap the drivers. The tweeter is not flat faced and is sculpted. I don't normally recommend 5.25" combos being above 3k in most 2ways, and 4k in 3ways, depending on drivers used. I would recommend an LR4 summation at 1.8k to 2.5k range, as the Continuum were at 1.8k with the same mids and the RS28.
Keep us posted,
These will be some imposing enclosures at 16" wide by 42" high!
Driver selection sounds nice. What do you have planned for baffle edge treatment to yield some reduction in diffraction?
hi thanks for checking in on this thread. I decided that I would start a new thread that followed a build from it's design stage through completion rather than a bunch of separate threads.Since I am not as accomplished as many of the readers in the forum I will be asking lots of questions as I go through the process. I'd like to thank those that have responded to my inquiries thus far and got me to this point. So let me share where I am.
I am building a 12 inch three way system. Selected drivers (based on lots of recommendations) are the SB 34NRXL75-08, the Arum Cantus AC130F1, and the Seas 27TAC/GB. I have received these drivers and QC'd them using DATS for rub and buzz. Currently I am designing the enclosure. It will be a 70L (internal volume) vented. I am oversized the cabinet by 0.8 cu ft to account for all internals. The front baffle will be 42" high by 16 inches wide. I am centering the woofer and it will be about 12" off the bottom. The Mid and tweeter will be off center mirrored pair such that the distances to the edges are staggered. Also the tweeter and mid have to be as close as possible (even slightly overlapping) since the XO frequency is 3300 hz. Once the cabinets are built I will take frd measurements. Kindly let me know if I am on the right track or missed anything important. I will post a diagram of driver locations on the baffle. Stay tuned and again thanks for your help.Tags: None
