Jims 3 way speaker build
I have not tried because I dont have a well designed crossover yet. I do have a XO that was designed in Xsim using manufacturers data. I understand the need to make measurements on the actual baffle so that is where I am at now. I COULD play the speakers usig the existing XO. It may not be great but may be close. What do you think??
A cursory glance suggests you have a leak around the port (it is not fully sealed) and the damping has reduced your box resonances.
When you have a leak, the impedance flattens out like that and does weird things.
Your box resonance has dropped from a 5 ohm peak to a 1 ohm anomaly at 150 Hz. It looks like the 650 Hz mode has been minimally affected.
Maybe the 650 Hz mode is the front-to-back cabinet dimension?
You can try maximally stuffing the box to see what it takes to completely kill them. I have measured in the past a slight increase in HD related to box resonances like these, but I’m sure you’ve tamed them enough to be inaudible 🤷♂️
Cheers!
Originally posted by gregrueff View PostA cursory glance suggests you have a leak around the port (it is not fully sealed) and the damping has reduced your box resonances.
Is the mid chamber damped on the outside top and bottom? I don't see any in the images. The 650Hz could also be the height from chamber to floor.
13560/distance = freq, or 13560/freq = distance; without factoring in quarter waves.
650Hz = 20.8", which looks pretty close to your issue.
OK so I have been delayed as I am waiting for damping material for the cabinet. While I am waiting I did have a couple of questions. I know it is nearly impossible to measure bass response in my room. I am crossing over my woofer to mid around 225hz. Instead of using my screwed up frd file should I use the manufacturers frd with my own generated frd of the mid and tweet on my baffle?
If crossing around 200Hz, your response is basically the "box response" as shown in any box simulator software (which doesn't account for room modes, of course). Most peeps who DO measure woofer .FRDs themselves "gate" (which limits the bottom end measurement below around 300Hz anyway), and then splice on the box-sim response below the 200-300Hz range.
Originally posted by johnny5jz View PostPost up your crossover schematic.
3-ways are often plagued more with low-impedance than 2-ways.
Are they all 4ohm drivers? (From what I can tell (YOUR .ZMAs) they're all 8ohm? A "typical" 8ohm 3-way might "min out" in the 5-6ohm range.)
Do you have a lot of overlap (caused by shallow slopes, AND a narrow mid band-pass - 3 octaves (or more) is best)?
It SEEMS (to me) that you might get a higher Z using a bandpass (mid) topology using a series cap, THEN your series coil, and THEN the shunts (to gnd)...
Not sure why this is, but I do think it's true.
Also, don't you need any attenuation on the tweet and mid? Series resistance will help hold your Z up (aren't you using any baffle-step?).
