I know it's not perfect and that the environment is a bit confined. But in 3 hours I was able to get full polars on horizontal and vertical for 2 drivers every 10 degrees.
I set listening height between the mid and tweeter. It's a bit physically high from the ground. But that can be changed in v2.
I did a bit of simple code to setup to give the vertical angle offsets. Horizontal on a notched turntable at 10 degrees per.
Eyes are a bit crossed from effort. But tempted to see the numbers on version with 1/2 roxul-filled cavities... Though these are full sized volumes designed around the drivers.
...excited for when the new tweeters arrive so I can get on the crossovers for this project
What would you recommend as things that I should be doing here to improve the acoustic performance and/or efficient use of this rig?
