which is the best midrange ???
  • which is the best midrange ???
    The dayton 2 " midrange the RS 52fn-8 or the Dayton RS 125p-8. i am wanting to know the likes and the dislikes of the two drivers '. most of all which one has the cleanest and purist sound.
    Or it can be any other driver that has a 5" flange and is no more than $50 apiece
      Prv 4mr60-4 is very good. There are many others worth noting.
      • dougc
        dougc commented
        Editing a comment
        Wolf who sells Prv drivers ??? I thought i seen them on Parts Express
      I'll be doing a build with that 4" "OEM" SB driver here soon. I really was impressed with what I heard of it running fullrange at Indy this spring. It is under $30, and has a very good response through the anticipated pass band, and models really well as a dedicated midbass for small 2-ways, as well.
        what SB driver is it ??
          What is wrong with the Dayton drivers that I listed? Theese are replacing the mids in my 5 driver towers that are 3-way .
            sb12pfcr25-8
            • AEIOU
              AEIOU commented
              Editing a comment
              Sensitivity is very low!
            Hi JR,
            I think Chuck had the 4 Ohm version of that driver at Indy, which has a much smoother in pass band response:
            - SB12PFCR25-4
            - same low price!
            - in stock at Madisound!
            Craig
            I drive way too fast to worry about cholesterol.
              I've had my eye on using the SB12NRXF25-8 for some time. Incredibly smooth response.
              Constructions: Dayton+SB 2-Way v1 | Dayton+SB 2-Way v2 | Fabios (SB Monitors)
              Refurbs: KLH 2 | Rega Ela Mk1
                dougc the two option you listed are like comparing apples and pears - assuming the 2” mid is the RS52AN dome mid range.
                The RS52AN-8 will only go down to around 500hz at a push, more like 700hz usable but will go up to 8khz plus and has a sensitivity of 89.4db/W/m. The RS125p-8 can be used down to 100hz but tops out usable at around 5khz and is 2dB less sensitive. Also the 2” can be placed like a tweeter in the same volume as the woofer whereas the RS125 will have to have it’s own enclosed (probably around 1-2litres, sealed). So, it really depends on what drivers are above and below it and what range you want them to cover. Finally off axis dispersion is different for a dome compared to a cone so this may be a consideration.
                Just a few thought.
                  Ok i'll give my main speaker bio. each speaker consists of 5 drivers, 2 Vifa PL18-8 woofers , 1 Vifa PL 18-4 midrange, 1 Infinity 5" mid (blown,replacing) ,1 BG neo3 pdr tweeter. They are awesome speakers but the 5" mid is blown. I bought them at a speaker close out @ PE about 12 years ago
                  • JRT
                    JRT commented
                    Editing a comment
                    If you still have your B&G Neo8 PDR midranges, then one each of those might work well as upper midrange paired with one each of your B&G Neo3 PDR tweeters. Use the pairs of Vifa PL18WO09-08 for lower midrange.
                  Hi Dougc,
                  The speakers will probably sound better with a single mid-range driver rather than multiples. More isn't automatically better with speaker systems. Might be better to ditch the extra mid-range driver to avoid destructive coupling/lobing/smearing/etc.
                  Pro/Fi Cinema Speaker project: "From the Ashes"
                  • dougc
                    dougc commented
                    Editing a comment
                    My speakers are more like 3 1/2 ways , it is divided in the midrange, so now I have a hole from about 1.5 khz to 3.5 khz where the tweeter takes over.
                  Originally posted by dougc View Post
                  Ok i'll give my main speaker bio. each speaker consists of 5 drivers...
                  So was this a kit speaker PE was selling or is this a design of your own?
                  Either way, if you can't purchase new units of the blown midrange or have them repaired you can't just swap in another midrange without redesigning the crossover.
                  The 'best' midrange is the one that integrates with your other drivers.
                    These are speakers that i designed and built.
                      JRT ; no what you listed ended up being my center speaker , and it sounds awesome.
