I'm not sure what the calibration curves are supposed to look like but surely someone here does. I purchased this 10ish years ago off of the PETT classifieds. At that point I'd had a WT2 for years and (mistakenly) thought the WT3 was an upgrade so I got it at what I felt was a good price w/o doing any research. That was also about the same time the Army took over a good chunk of my focus and it sat in the small flat rate box that I received it in until recently. I currently have 3 or 4 things I need to measure with it.
To make matters worse, my laptop runs Windows 10. I'm not the most computer savvy and I had to send several hours digging through old forums (mostly this one) to get the audio setting to function correctly. I'm fairly confident I got that figured out but I've included them in the screenshots just in case.
ASSUMING these curves are in fact wonky, they do look good at least to 100Hz. Would data measured below that point be valid? I need to measure three two subwoofers and a woofer. I also need to measure some inductor values but I'm not sure if I'll be able to do that with this.
"impedance" curve is the calibration with the included 1000 ohm resistor (995 ohm actual)
"leads" curve is the calibration with the leads shorted
