I was looking at my Sony AVR . It allows 6 ohm speakers. It also has Speaker A, and Speaker B connections that can be played simultaneously. (They are connected in parallel.) So, I would conclude that I can run a 4 ohm speaker easily if I'm just using Speaker A connections. (Unless the manual is wrong.)
I also see where I can select 5 channel stereo, and the same sound goes to the back speakers. What I'm considering is a a 3-way with the mid and tweeter on the front outputs, and the woofer on the rear output. I should be around 90dB on the mid/tweeter, and 87dB on the woofer. On the AVR, I can adjust "speaker level" by 3 dB to pad the mid and tweeter to match the woofer. The x-over might get "interesting", but that's OK. This could also work for a 2-way. I have some tweeters that I think are about 94dB. The AVR has decent power already. This setup would improve on that with the trade-off of additional complexity.
Has anyone tried this? Is it worthwhile, or just silly for a small headroom improvement?
