Crossover Help - Epique & BZ Project
Originally posted by jml View Post
Thanks! What does the mode delay do?
In looking more at the response I posted above, I was confused why the midrange breakup was coming through so much more than in the model. It turns out that if you drop a 22 ohm resister into the notch filter instead of a 2.2 ohm resister, it's not going to work right haha! Here is the updated graph with the rectified resister value.
Cheers!
Joe
- Likes 1
Originally posted by 4thtry View PostCan't help with series crossovers, as I do not know much about them. However, a few years ago I put together an XSim step by step guide listing my steps for designing crossovers using OmniMic, XSim, and DATS V2 (attached PDF). On your latest crossover CAD screen, it does not appear as if you have included XSim's "mod delay" in your model. When the proper "mod delay" is included, as small "m" will appear after two of the three driver names. For instance, "S1", "S2m", and "S3m" instead of just "S1", "S2", and "S3".
[ATTACH]n1495645[/ATTACH]
XSim step by step2.pdf
Good Evening!
I felt like it was time to try something new with the crossover model. I've never designed a series crossover before, but figured that it was worth a shot. What do y'all think of the below?
- Woofer crossover point is probably still a bit high.
- The midrange breakup is mostly tamed, but there is still some noise around 4k.
- Component count is getting high, but feels manageable.
- The series crossover seems to have significantly improved the low impedance issues I was having previously
Thanks in advance for the feedback!
Joe
- Likes 1
All:
My apologies for the silence over the past couple of weeks. Between work and family, I haven't had much time to spend on this project recently.
Wolf, I appreciate your clarification around the different approaches being suggested for measuring. I looked a bit at VituixCAD, and it sounds like something worth transitioning to over time, but for now, I think I'll stick with Xsim.
All of my initial measurements have been taken at what will approximately be ear height of the speaker when seated - on what I consider an average couch for an average person anyway. If this is "acceptable" when modeling in xsim, then I'll plan to continue to do so.
As for the wiring - with the 8 VCs in each speaker, they're wired series-series- parallel - each DVS woofer wired in series up to 8 ohms, then the top and bottom woofers wired in series up to 16 ohms, then the two pairs wired in parallel down to 8 ohms.
Cheers!
Joe
FYI, Dezzar and JohnH are advocating for different style models.
Dezzar will want all drivers on their axes as well as off axis to model for a directivity index in VituixCad.
John is going to use PCD or Xsim to find relative offset at the listening position and requires all measurements initially to be on the main listening axis. This is for one axis only, but the most important one, and once developed, off axis measurements or models will be further verified.
Neither is wrong.
Also, I'm uncertain about your woofer wiring. These are DVC woofers, so you have 8 voice coils. Are the "bottom 2 in series" wired with all 4 coils in series to 16 ohms net?
Just FRDs when doing combined measurements TW plus mid, TW plus 4 woofers. We need to find the delay between drivers. If all 4 woofers are in the same enclosure you should measure together. You can't get a accurate measurements if you are disconnecting drivers in the same enclosure. Your impedance measurement will also be a problem if you want to separate the bottom 2 woofers for a 3.5.
As long as the mic position doesn't move the measurements will be good. Better to have the mic position on the listening axis.
