Hi,
I have posted before on this forum about my recent purchase of a pair of vintage AR-LST speakers from the 70ies.
The overall impression is impressive (!) When fed with a little more than ”casual-listening-power”, they come alive and deliver, especially after a period of burning-in after being in storage for many years (and som new caps and woofer surrounds)
But, as usual being an engineer, I investigate the system.
Now, this AR speaker is based on a principle, ”acoustic suspension”, that the air volume inside the box serves as a ”spring” and controls the 12” woofers behaviour. In this situation I believe that it is imporant that the cabinet is strong enough to hold the pressures inside and not to flex.
The back of the LST is 70x50 cm 18mm fiberboard and completely without bracing. On top of this, there is a internal plate in the center, holding the heavy XO. When feeding the speaker with bass-heavy music, one can physically feel that the backplate is flexing in/out. I feel that this is not the way that the woofer-part of this high-end speaker was intended to work.
What to do? I think that one has two ways to deal with this: One is to brace the backplate, probably on the outside. Doable but one has to dig into the box and attach screws from the inside to 2 or 3 glued 2”x2”-braces on the back.
Another option is to glue a 1” plate on top of the whole back-plate (and cut a hole for the connectors of course)
Please, give me your thoughts on this. Am I basically wrong in this? If not, which ”bracing-principle” do you recommend?
Best regards//lasse
Stockholm, Sweden
Best regards//lasse
Stockholm, Sweden
