The latest iteration of the Ghettoblasters has taken me to using a ND65-4 drivers, paired with a ND90-PR (Each).Originally i was only wanting to print something that would fit on my 3d printers in entire pieces, but none of the concepts could house the ND65 driver nor the Passive Radiator that i wanted and maintain a similar height/width/depth relationship, which is something i find a must. So settled with ND65-4 in an enclosure of 0.034cuft and having the PR with no additional weights. This appears to give a F0 of 85hz (F3-78hz , F6- 74hz and F10-69hz) and similar tuning of F0 84hz (F3-70hz , F6- 64hz and F10-55hz). If i add 2grams to the PR's it drops down a little but peaks at F1.5 at 73hz, and drops the rest around 4hz at the other frequencies, same goes for the driver and i'm not sure if thats worth doing and happy for some advice around that.
The amplifier for the build is intended to be a KAB 230v3 and hoping to match it with the equivlient KAB battery board (read that the LBB isnt suitable for the KAB's), but considering not using Dayton Audio at all and going Wondom as i cant find anything of use for the documentation with the DA products and on most forums nobody ever replies.
This one will have a secondary power supply/chain as i will also have a ESP board and SPST slide switch running a 3inch screen and having an animated GIF of a cassette tape playing. This i have actually running and will look pretty cool. I'm also looking at a 5v flashing light bar that is meant to move based on a mic on the circuit, but not sure ill add it yet as i dont like the few options it starts off with when turned on.
Something i'm noticing on projects to date is the 18650 and 18350 batteries seem to have a short lifespan and a little disappointed with the Sony VTC range, so unsure ill be using the remainding ones i have or go down the Samsung/LG path.
The front design is taking me a little longer than i thought it would as there are a lot more parts to consider than the DMA45 variant, but will be removing the manufacturers name this time. Would love to know what the font name is so i can at least get something similar looking to the SHARP branding.
