I'm going to be building a pair of Wolf's Nephila's for my niece (a wedding present). I'll be using a "double baffle" approach that I've used in previous builds to accommodate a solid wood baffle - so the outer dimensions are adjusted accordingly so the internal volume stays the same as Wolf's design.
Pile of wood:
Glue up:
Cabs without inside baffle. I used bondo on the butt joints at the top/sides just so there's no bleed through the veneer. The other joints are on back/bottom so I didn't bother smoothing those out.
Next question, Wolf's design calls for stuffing as follows: "1(bottom) was completely stuffed with 3oz of polyfill, 2 had 2oz, 3 had 3oz + Sonic Barrier, and 4 was thickly lined with Ultratouch Denim insulation". I have polyfill and this acoustic foam:
I was just going to swap out the sonic barrier and denim insulation with this foam and then stuff in polyfill as per Wolf's descriptions. Thoughts?
Pile of wood:
Glue up:
