Provided Link: More Pics
Acoustic Elegance (formerly Stryke) is gearing up to go back into production, building their own drivers as well as some of the older Lambda designs. John had a couple of prototypes of the new version of their AV15 sub and I was able to score one. It's not identical to what the production version will be, but pretty close. Mine has a thick aluminum sleeve around the pole piece, both to wick heat away from the coil as well as to reduce inductance (i.e. less compression, harmonic distortion, etc). The production version will use a copper sleeve. This is a monster of a driver - 23mm xmax, 1500W power handling, and built like a tank.
The parameters allow for a variety of uses. I'm using mine for HT duties, and it will be going in about a 6 cuft box tuned around 20 Hz. You have to get up to around 1500W before you start running into xmax issues (below about 15 Hz).
I'm going to attempt a curved sided box, so we'll have to see how that works out. If nothing else, Andy should be proud I'm stepping outside the (square) box.
