If you have an immediate customer service issue, please email Parts Express at [email protected] or call 800-338-0531, Monday-Friday 8am - 6pm EST.
Raw MDF is ok to burn but I wouldn't stand around breathing it. It contains the glue that holds it together including formaldehyde (a purported mild carcinogen). Light it, stay out of the smoke cloud, and your exposure will be minimal. Not a big deal.
Laminated MDF, (Melamine or HPL) should probably not be burned without special equipment.
Never burn PVC. Its byproduct is Dioxin, one of the most poisonous substances.
Happy Bonfire,
bb
Since we cannot know all that there is to be known about anything, we ought to know a little about everything. - Blaise Pascal (1623 - 1662)
> I have a lot of scrap I'd like to burn it in
> the fire pit..is this gonna cause me
> problems?
No, it's fine! BURN IT!!! I heated my old shop one winter with MDF scraps, totaly safe, all the smoke went outside. I burned it in a wood stove.
It's going to decay and release toxins no matter what you do with it, you might as well get rid of it.
> Oh come on. The amount of toxins released by
> the burning of MDF is miniscule, unless of
> course you put it in Vas's bong and inhale
> deeply.
As an environmental engineer who has done work in both air pollution and solid waste management, I would strongly suggest *not* disposing of anything by burning except natural wood, brush, and paper. Even then, it's not good if there happens to be a high level of fine particulate in the air on that particular day (you can find real-time air quality data on epa.gov and also some state agency web sites).
A backyard burn pit just can't have the proper temperature and combustion air conditions to allow anything to burn cleanly.
In addition to air toxics that are released, just the fine particulate (regardless of the actual composition or chemistry of the fine particulate) have been demonstrated to increase hospitalizations and deaths from heart disease and asthma.
It's really better for things like MDF to go to a landfill or a municipal waste incinerator (which usually have at least decent air quality controls).
> agency web sites).
> cleanly.
I use MDF scraps to light my fireplace wood during winter.
At most, I may "burn" a third of a sheet of MDF in scraps each year that way. I'm not worried.
> during winter.
> I'm not worried.
Well, what you're doing is quite different from what the original poster was asking. Personally, I wouldn't start a fire using MDF scrap, but it's a lot better than burning it for disposal. In your case, there would be a lot more oxygen to support combustion. But still, the products of combustion won't be fully broken down. Also, fireplaces aren't good for preventing combustion byproducts from being released into the room.
> deal.
Well, no. In practice, there's no way to avoid breathing at least some of it. Also, what about the neighbors and the wider community? See my posts below....
> equipment.
True, plus there are all kinds of other toxics generated.
If you are talking about a fire pit on a deck or something, you'll be okay njust burning the MDF by itself. I've even burnt wet mdf and other woods by smearing it with liquid nails first then lighting it. It burns like crazy. If your in the yard though you can pour some kerosens on the wood before you light it to help it burn. Don't use gas because it might explode and don't put it on after you light it. Kerosene will help it burn real good though. I used to do construction and we would burn all the scrap wood and vinyl sidding in a hole with kerosene to keep warm.
