I love your website... great info!! Are you ever gonna test the new TB's?? The 3" dome and the new woofers look -- v-e-r-y -- i-n-t-e-r-e-s-t-i-n-g --
Hey John *Zaph*!!
Re: Hey Mike !!
If you want it tested you buy one or two, submit it/them for testing, and wait until Zaph has enough time and enough other items in that size/catagory to justify setting up the jig for testing them.
As for "-- v-e-r-y -- i-n-t-e-r-e-s-t-i-n-g --" . . . well . . . maybe sort of. As with any driver that size you'll want to get off it around 3kHz into something like a D26 or a ND20 (or a little ribbon if that's your fetish), just as you would with a RS52 or a RS100 (half the price). On the low end it probably goes a bit lower than the RS52, although not by much, and nowhere near as low as the RS100. You'd use it with the same mid-bass as a RS52, only changing the crossover by maybe 100-200 Hz. The RS100 opens the possibility of crossing straight to a subwoofer style driver (like the RSS series), which actually *is* "interesting". Any of them would do fine with a RS225.
So . . . modestly interesting, maybe. At half the price . . ."It suggests that there is something that is happening in the real system that is not quite captured in the models."
Re: Hey John *Zaph*!!
The RS100 wouldn't be too useful in a three way with its low sensitivity, unless you went active, but why have a massive speaker thats also inefficient?."I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
the sensitivity
of the RS100 isn't all that out of line if you consider baffle step correction, which eats up 4-6 dB of the "extra" sensitivity of a 86-87 dB woofer. You just have to size the enclosure and pick the crossover frequency such that all the bsc come out of the woofer . . ."It suggests that there is something that is happening in the real system that is not quite captured in the models."
Which means you're still not going to get the crossover point much below 500-600hz, so might as well use the RS52. The RS52 has ridiculously low distortion numbers and a near perfect responce on and off axis so theirs little reason not to use it, unless you really want a cone mid."I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Originally posted by AJ View PostWhich means you're still not going to get the crossover point much below 500-600hz, so might as well use the RS52. The RS52 has ridiculously low distortion numbers and a near perfect responce on and off axis so theirs little reason not to use it, unless you really want a cone mid.
lower than that . . .
If you're using a 12" woofer the baffle is going to be 14-15 inches wide, and the baffle step will be around 300 Hz. Neither of the domes will go that low, but the RS100 will . . .
The RS52 does have very low distortion . . . the problem is finding a large woofer that has low distortion up to 700 Hz to match it. Most designs seem to end up doubling up (or quadrupling) 6 1/2 inch drivers to get the surface area, but it's still hard to match the x-max and total displacement of a good 12 inch."It suggests that there is something that is happening in the real system that is not quite captured in the models."
Re: lower than that . . .
Originally posted by Deward Hastings View PostIf you're using a 12" woofer the baffle is going to be 14-15 inches wide, and the baffle step will be around 300 Hz. Neither of the domes will go that low, but the RS100 will . . .
The RS52 does have very low distortion . . . the problem is finding a large woofer that has low distortion up to 700 Hz to match it. Most designs seem to end up doubling up (or quadrupling) 6 1/2 inch drivers to get the surface area, but it's still hard to match the x-max and total displacement of a good 12 inch."I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
good "sub" driver
The RSS315HF does respectably well up to 300 Hz. The HiVi M12 is another candidate. And of course there are lots of 10 inch drivers to consider too.
Big box speakers with a 12 inch woofer, a mid and a tweeter may not be in fashion these days, but they've been around for a long time, and benefit from the newer drivers just as much as any other design does. We tend to dismiss them now because the advent of HT and the "sub-woofer" has all but eliminated the true "full range" speaker in favor of "monitors" and mtm boxes with 6-7 inch mids. But "fashion" doesn't mean it's not possible to build a good old fashioned three way around a RS100 covering 300-3000 Hz."It suggests that there is something that is happening in the real system that is not quite captured in the models."
Re: good "sub" driver
Originally posted by Deward Hastings View PostThe RSS315HF does respectably well up to 300 Hz. The HiVi M12 is another candidate. And of course there are lots of 10 inch drivers to consider too.
Of course Deward, anything is possible. I just throw out my opinions. At the end of the day, does it matter which mid you used as long as the speaker as a whole sounds good? Hell no."I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Originally posted by AJ View PostOf course Deward, anything is possible. I just throw out my opinions. At the end of the day, does it matter which mid you used as long as the speaker as a whole sounds good? Hell no.
Still, an RSS315, RS100, RS28 system would be pretty nice for sure. You'd need a 250W amp at a minimum though. And asking the RS100 to cover that range at SPL levels to keep up with the RSS315 would be a stretch, thermally speaking. A pair of them, MTMW style would probably be a better bet.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
it's not like
it hasn't been done before . . .
The Thiel 3.6, for example, used an only slightly larger (4 1/2 inch) cone midrange (built on a Vifa PL11 frame). It used a 10 inch woofer (not a 12), but since it "featured" first order crossovers the woofer had to reach significantly higher than would a 12 inch behind a LR4.
Not that I'd particularly advise building a big full range around a RS100, but the OP was asking about 3" domes . . . in that context the question becomes "what does a 3" dome bring to the table", and my answer, basically, was "less low end extension than a RS100, and not enough more than a RS52 (at half the price) to matter".
The RS52 is a great driver, but it poses a problem filling in under it. Your DA-175 towers is one way . . . a single 6 1/2 plus a sub (making a four-way) is another. Yet another option would be one or two RS225.
The RS100 just asks different things of the driver used under it.
There are far more choices (options) when building speakers in boxes than there are when building dipoles, for example, but the basic reality remains that driver choices are a "package deal" where each choice influences, and sometimes necessarily changes, the choice of other drivers in the system. There are lots of ways to build speakers-in-a-box . . ."It suggests that there is something that is happening in the real system that is not quite captured in the models."
shawnMy favorite woofer is a Labrador retriever.
Re: it's not like
Originally posted by Deward Hastings View Postbut the OP was asking about 3" domes . . . in that context the question becomes "what does a 3" dome bring to the table", and my answer, basically, was "less low end extension than a RS100, and not enough more than a RS52 (at half the price) to matter".
I don't know of any others out there than these.
