I am building my own speakers into the walls of my home. I am using 2 61/2 woofers and a tweeter for each output of the home theater set up. I also have a powered subwoofer and a manufactured center channel speaker. I understand the crossovers but I don't know exactly how to maintain 8 ohms of impedance when using 3 speakers. Do I add resistors to equal 8 ohms with the speakers in parallel ? How does this work
Impedance matching ????
Re: Impedance matching ????
Originally posted by cblinko View PostI am building my own speakers into the walls of my home. I am using 2 61/2 woofers and a tweeter for each output of the home theater set up. I also have a powered subwoofer and a manufactured center channel speaker. I understand the crossovers but I don't know exactly how to maintain 8 ohms of impedance when using 3 speakers. Do I add resistors to equal 8 ohms with the speakers in parallel ? How does this work
If your woofers are 8 ohms then in their passband they will either be 4 ohms (parallel-wired) or 16 ohms (series-wired). Not really any way around it. Adding resistors is not a real good idea as this will alter the parameters (Q) of the woofers and if you expect to drive them with much power you will need very large power resistors to dissipate the heat.
4 ohm loads are not too big of a deal for most decent amplifiers. Helps if you post what kind of drivers you are using.
DaveDave
If you can read this, thank a teacher.
If you are reading it in English thank a Veteran.
