Re: Controling Cone Breakup In An Active System
Therein are two of your flawed assumptions. You assume that the effect of cone breakup is confined to or resides primarily in the breakup region itself. And you assume that the distorted signal represented by the peak will be effectively masked by the undistorted signal from the tweeter, rather than appearing as distortion of that signal.
There is a world of evidence that simple harmonic distortion at levels up to 1 percent or more is either not perceived, or where perceived is regarded favorably (SET, for eample). The same is not true for intermodulation or spectral contamination at that level, which is both perceived and regarded unfavorably.
Originally posted by jkim
View Post
