Finally Zaph added some pro drivers to his 6.5" test group. The results are very interesting. It turns out that the light cone, high efficiency design of pro midrange drivers is achieved only at the cost of low end extension, but not at the cost of distortion performance.
The use of these drivers should be different from that of others in the group. They are not suitable for a 2-way design. We can evaluate their performance only above 300 Hz---perhaps above 200 Hz for the 18Sound 6ND430-16. The distortion level of the 18Sound is amazingly low. It is comparable to the best hi-fi driver in the group in the 200 Hz to 2 kHz range---the Usher 8945P. Its frequency response is linear. Sensitivity is over 89 dB at 16 ohm nominal impedance! I'm not sure its 8 ohm and 4 ohm versions are available. If so, I'd expect the same level of performance with higher sensitivities.
The B&C 6MD38-8 is also an excellent midrange driver. 400 Hz is the lowest xover point I'd use with this driver, though.
These results suggest that we don't need to use more expensive hi-fi midrange drivers like SS 12M or 15M to achieve ultimate performance.
This time Zaph added two more hi-fi drivers---Usher 8836A and the new Tangband W6-1721. The 8836 result shows Usher's consistently good motor design. The new TB's motor also turns out to be excellent. 2nd order harmonics at 800 to 1000 Hz are a bit high, though---I don't think 2nd order harmonics in this range will be very obtrusive. At $52, it is very attractive. According to Zaph's FR measurement, it seems that it won't need much BSC in a 2-way design, so its relatively low sensitivity won't be a drawback.
Thanks for the work, Zaph!
-jAy
-jAy
