Originally posted by daryl
View Post
And if you bother to take ESR into account in the models, the effect on Q in the networks can be exactly modeled. You do it with coils, and it works the same way with caps. This is the biggest mistake people make when using electro's IMO. Of course it's going to sound better with a lower-ESR cap when the network was designed and optimized for a cap with zero ESR. That's also why you don't seem to "need" anthing other than an NPE for a zobel (or circuit which looks like one). There's already a 4-10 ohm resistor there, what's a few tenths more?
The biggest beef I have with NPEs is all the little pieces of paper inside the cab when it goes kabang. With DFs of 10 to 20%, the ESR can be high and they will get hot. For speakers that will be subject to 100 watts or more average power, it's a good idea to use caps designed for switch mode power supply filtering if you need a big electrolytic. Need to make an NP out of two back to back. Those caps have low DF and can take several amperes of ripple current at 100KHz or more without overheating.
