Well, here it is. I finally got it finished and put together. I am running th NHT buyout 100w amp with 4 TB W5-1138SM 5.25" subwoofers in a 2.0 ft^3 vented box. This project exceeded my expectations. I am very impressed with it. So, if anyone has 4 of these laying around I would highly recommend throwing one together. Or have Nik build it, he built this one and did a fantastic job.
4 x TB W5-1138SM Sub Tower
Re: 4 x TB W5-1138SM Sub Tower
wow, that looks great, i like that you painted the port back. what was the f3 in the simulation on that?Check out my website: www.uberstealthaudio.com.
Now offering cnc cut baffles and other speaker cabinet parts
25Hz. I just hooked it up and played it. Bass is much weaker than the other. I think it might have something to do with lining the sides back and top with 1/2" black foam rubber. I didnt do anything to the other one but mount the drivers and wire it up. I might have to try to remove the stuff when i get back from new york. Did you make the dimensions exactly the same on this one? I noticed that the top driver is much closer to the top on this one than the other one.
Thats funny you ask because this brings up a concern. The new box is roughly 10.5x19.75x39. Nik, any idea what happened here? This box is 3/4" shorter than the other one. Thats where that space went on the top. Also, i have 3/4" foam inside lining the walls. Need to figure out where the performance went. I didnt think that lining the walls would reduce the volume. Anyway, let me know what happened with the dimensions.
same parts, same program. not sure how 3/4" got lost. I must have inset the top panel vs setting it on top. That small of an area would make little to no difference in a box that size. you lost about 7" c 10.5" x .75" or .031 cubic feet., or .015% of box volume. I think the new box would actual the be right one. I may have made the old one too tall. I bet you just have a amp setting or stereo setting, as i could not imagine lining the insided have any major afffects, exspecialy negative. The only other differnce is the port isd trait on the inside this timeCheck out my website: www.uberstealthaudio.com.
Originally posted by aaronscalise View Post25Hz. I just hooked it up and played it. Bass is much weaker than the other. I think it might have something to do with lining the sides back and top with 1/2" black foam rubber. I didnt do anything to the other one but mount the drivers and wire it up. I might have to try to remove the stuff when i get back from new york. Did you make the dimensions exactly the same on this one? I noticed that the top driver is much closer to the top on this one than the other one.
With all those woofers, make sure you don't have one out of phase. Connect a battery to the terminals and make sure all the woofers move in unison. One out of phase will play hell with system response.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
Weaker? Weaker how?
Originally posted by aaronscalise View PostWoofers are wired properly and are all in phase. nik, there is no stereo setting on the amp. Hmmm. i'm going to have to mess with this more when i get back. I've been listening to it and its alot different from the old one. I think i'll start by ripping out the foam.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
how are you wiring them, series then parelle to keep it 4 ohms? i am leaning towards 1 wire got swapped and you are running a 8 or 16 ohm load, just my idea, i have done it beforeCheck out my website: www.uberstealthaudio.com.
Originally posted by nikbrewer View Posthow are you wiring them, series then parelle to keep it 4 ohms? i am leaning towards 1 wire got swapped and you are running a 8 or 16 ohm load, just my idea, i have done it before
Originally posted by gregrueff View PostWas the old box braced poorly or otherwise not as well built as the new one?
Could you have lost some panel flex, and perceived it as a loss in bass?
Is the new port tuned as the old one?
Greg
port is exactly the same, and from looking, the first box was too tall, so size should not be a problem.Check out my website: www.uberstealthaudio.com.
