Building a Crossover (not designing a crossover)
My Home Theater Build thread
My DIY Speaker builds
My Gear:
Emotiva XMC-1
Emotiva XPR-2
Emotiva XPA-5
Clearwave Dynamics 4T and 4CC (mains)
Paradigm Millennia LP (surrounds)
Oppo 103D
Mede8er 600X3D w/ 4TB
Marantz CD-5004
AppleTV
JVC RS-4910 Projector
100" Screen Innovations Pure Gray Screen w/ LED kit
APC Uninterrupted Power Supply (x2)
iRule controlling it all.... -
Re: Building a Crossover (not designing a crossover)
There are certainly better looking crossovers than mine out there, but I'll post some of my work. I secure the components with hot glue and zip ties. I like using terminal strips to make hookup and possible removal easy. I use solid core copper wire behind the boards to make any connections.
ZDT3 (I have since changed out the screws holding down the large ferrite core inductor to zip ties. Using screws is a no-no in such a situation.)
ZDT3.5
ZDT3.5 Center Channel
General wiring layout behind the ZDT3.5 crossovers above. Red is positive to a component, white is ground to a component, blue is a path straight to ground.
You may need a login to see these pictures, but check out these:
http://www.htguide.com/forum/showpos...2&postcount=56
Thanks for the pics. This is really helpful and helping me understand even more about crossover building.My Home Theater Build thread
My Gear:
Emotiva XMC-1
Emotiva XPR-2
Emotiva XPA-5
Oppo 103D
Marantz CD-5004
AppleTV
I think that plain old hot glue and cardboard works really well...
The cardboard is easy to cut, and hot glue sticks extremely well to it.
Not gonna win any beauty contests, but it gets the job done. Easy and cheap.
(yes, I realize the inductors aren't optimally configured in this pic...)
I've used hot glue several times, works great. But if you ever decide for whatever reason to dismantle/change the crossover, you might have difficulty pulling the components off of the solid glue. I prefer to use double stick tape to hold down my components. Easier to peel it off if you ever need to.
Originally posted by lunchmoney View PostI think that plain old hot glue and cardboard works really well...
Lots'a way to skin a cat, as they say. I like to run a common ground down the center of my x/o board and build off that. As mentioned before, it doesn't have to be pretty, just well soldered! This is one I whipped up for testing - would have shown you the 'final' version but I never photographed it!
If you search for a thread entitled: "Physical Xover pics, post 'em if ya got 'em", you'll find a mess-load of pictures. It's a good thread in regards to building them.
Curt C's site has a tutorial, as well as PE having one in their technical pages.
I like peg-board and zipties, maybe some glue if required. Point to point soldering is the best and shortest path, and keep Inductors at a right-angle.
Here's a recent one:
Here's a pic of my ZMV5 crossovers when they were under construction.
Note the strips of wood on the bottom. When wiring the crossovers, they elevate the board from the table so that twisted-but-not-yet-soldered wires don't get bumped loose on the bottom. Later, I just put wood glue on the bottom of the wooden strips and dropped the assembly into the cabinet to glue the crossover inside. The screws in the corners of the crossover boards let me remove them if I need to later.
I used nylon screws and nuts to attach the solder strips on this build because I know that an inductor may be placed nearby. I didn't want the hunk of steel affecting the inductance.
While I used Radio Shack solder terminals on this build, NEVER AGAIN! The holes are simply too small for more than two wires at a time. (Anyone know of another supplier of solder terminals?)
Dave,
Those are brass nuts and bolts, right? Something about creating lots of little inductors with anything other than that...or so I've read....
Gotta admit, it's a pretty cool looking x/o!
Originally posted by Hackomatic View PostYet another option . . .
Re: Building a Crossover, pic-thread link added...
Originally posted by Hackomatic View PostYeah, all bass hardware . . I decided to do it this way only to make component swapping easy if necessary.
. . and because I had all the brass hardware!
Here's the former thread with xover pics...
http://techtalk.parts-express.com/sh...cal+xover+pics
I built the BAMTM crossovers using project boards from Rat Shack.Last edited by Steve Henry; 04-10-2011, 09:32 PM.Audiophiles listen to the equipment, not the music.
So many great options. I'm getting excited to start my first crossover build. I'll be sure to post pictures of my process/progress once I get started.My Home Theater Build thread
My Gear:
Emotiva XMC-1
Emotiva XPR-2
Emotiva XPA-5
Oppo 103D
Marantz CD-5004
AppleTV
