I have a pair of beefy multi-tapped toroidal power transformers, probably 300W. These came as part of a plate amp from a pair of active loudspeakers. I bought then on Ebay for next to nothing. I have:
49.5V-24V-0-24V-49.5
taps to play with. I have bought a pair of LM3886 modules that I plan to put on to the +/- 24V leads to give me about 34VDC rails.
I almost found a perfect match for the other taps: there is an amp sold at ApexJr called the "Cerwin Vega full range" that needs to have its 220V transformer replaced with a 120V version. The amp needs 63VDC rails, but the 49.5V taps would be giving 65VDC. It's close, but I chatted with Neil Davis about it and he thought that pushing the output devices any more past 63V might invite disaster as it is on the edge of the SOA. I am still thinking about this, as it would be purrr-fect use of all the taps of the tranny in an active speaker. I should probably hook it up and measure the actual no-load voltage at the taps in case it is a little lower, and there will be some sag under load I assume...
I could also use two more LM3886 based amps that are each powered off of one of the 49.5 taps as a single supply amp. I could do this for two woofers (for instance) and power each one from one of the LM3886s. This would be the equivalent of AC +/-24.75V giving rails that were 0V and +/-70VDC. I would need some kind out output cap to kill the DC to the speaker. I see that there is a design for a single end power supply in the LM3886 datasheet so this is definitely a possibility...
But I thought I would throw this out to all of you to see if you had any other great ideas on what to do with the 49.5V taps. Your thoughts???
-Charlie
-Charlie
