Da175-8
  • Da175-8
    Can someone give me the true t/s numbers for the da175-8. when I try to enter the numbers given, in WinSLD pro they don't work. thanks for any help you can give me. Richard
    Re: DA175
    Zaph uses that speaker in his BAMTM design, you could use his test results which you can find here: http://www.zaphaudio.com/6.5test/compare.html
    EDIT: Oh, and do you mean WinISD (not WinSLD)?
      Re: Da175-8
      When using WinISD, don't enter the Qts spec. Allow the program to calculate that one for you. WinISD uses Qms and Qes to generate or verify the Qts figure. If you enter a Qts that varies any at all from the calculated value, the program will reject it.
        Re: Da175-8
        hey thanks for the help I'll try that and get back to you. Richard
          Re: Da175-8
          worked like a charm! thanks guys,Richard
