Hi, I am new to this forum and also new to DIY, in terms of practical experience, but I've been reading and researching in the past many many months and I think I am ready to build my first project:
Projects I have read include conventional TM/MTM/TMM 2ways, and all types of 3ways, full rage projects (e.g. using the markaudio CH70 drivers), subs, and line arrays.
I believe I have sufficient electronics knowledge to build XOs etc, but not the experience to design them, so I have only planned to build existing projects.
I have no experience in building boxes and this is what scares me, but I do have a friend whose uncle is a skilled carpenter and will be able to help me/provide tools.
So, with my above mentioned experience, I decided the easiest type of speaker to build would be something along the lines of a single fullrage driver sealed/BR (so no XO or just a simple filter) or a fullrage line array (again no XO, or complicated boxes with different mounting options etc.)
basically I am keep coming back to 'fullrage' for the easiest and simplest implementation. Am I correct?
So, anyway, I have finally decided to build a line array such as this:
http://www.parts-express.com/project.../Kuze3201.html
Looks like I can just slap a load of drivers connected together into the right impedance in a line, maybe add a filter, a bit of external eq, pair with a sub, and I'll get great sound? Or is it much much much more complicated than that?
Anyway, lets say I go ahead with this project, I'd like to go super budget and use these drivers:
http://www.parts-express.com/pe/show...number=289-124
1.
I cannot find any info on these things or anyone else using them. Are they suitable? IS this a bad idea? Any better suggestions for a better driver that is not significantly more expensive?
2.
I'm gona get 100 of them so they will be $2 each, how many should I have on each side for the average size sitting room, used for music as well as HT, paired with a 12" ported sub?
3.
Do I need to model them on computer and design an enclosure for them? Or can I just mount them in a pipe like the showcase or some kind of long thin box? If they need a specifically designed airspace/box can someone please help me and give me some suggestion? should it be ported? sealed? how big? etc.
4.
Do I need any electronics such as XO or filters for something like this? If so, any suggestions? A 100Hz highpass? so just a simple cap will do? I was hoping they would be ok full range.
5.
What is the best way to build the baffle for mounting all these little speakers? Do i need to drill 100 holes on a plank of wood to mount them? Or can I have 2 long planks of wood side by side, 2 inches apart, and just mount the drivers between them - but then there would be slight gaps between the drivers that need to be sealed?
any other advice would be greatly appreciated.
best regards.
1.
2.
3.
4.
5.
best regards.
