So I've been throwing out system plans for some time now, but finances have kept me from building anything!
I'd really like to do that 8945A/Neo8 business, but recent events have made that impractical.
I've designed a pretty simple two-way using the SB Acoustics 5" driver and the 810921. Really low distortion, excellent frequency response, and so forth - not difficult with drivers of this quality.
Now, since I recently got back a hold of two L26RFX/Ps I once owned, I modelled one of them as a subwoofer and it turns out the thing would be flat to 20Hz in-room (and, of course, SEAS drivers have ridiculous excursion capability, so it could probably actually GET that low.)
So here's the plan: build the two-way and the SEAS sub - which, btw, is going in a 1 cu. ft box with an aperiodic vent, and will use the dayton amp with 6dB of boost at 30Hz - and call it a day. Low-distortion and good power response, as well as excellent frequency response, from 20Hz-20Khz. Dream come true, right?
Well, truth is, even if they lack ultra bass, I've always preferred full-range 2-ways. The SB driver above is slated to be placed in a .2 cu. ft net box and crossed over at 80 or 100Hz LR2, which allows it to take about 100 watts.
I certainly can't build a full-range two way (say, with the 8945A) for about $350, which is what I estimate the total system cost will be at this point, including things I already have. But do you all think it's worth it to spend a little more? What are your thoughts on sub integration?
Also, one or both of those L26's are for sale, as well as two XT25's and some PL11-04's. Way cheap. Look in the classified section.
