Got my "Athos" drivers today.....
  • Got my "Athos" drivers today.....
    First off, Thank you PE for the prizes allowing the purchase for these parts.
    This will be a vented 4-way, not unlike the Icthus in inspiration. Athos is meant to be the *upgrade* from Icthus. It will most likely NOT be inverted, due to placement with sooooo many drivers and cabinet size. I am still playing with aesthetics, so this may change.
    Sorry for the blurrrrzzzz...
    I will have to see what CTC issues present, but these drivers are what I'm using.
    Now- some unit observations....
    The ND28F-6 has a variance in plastic-color than the previous units I have. These are more charcoal-textured-black, and the previous units were flat-textured-black. So they are a little lighter in color. No matter for me, as I'll be painting the faces to match the W3 midranges. These are very clean tweeters, but I wanted more dispersion on top, so I got the 13-'s as well.
    The TB crew has apparently snuck something by us in the W8-1363SB without it being recognized. These venerable monsters now have a **double-spider**, and it is not mentioned in the specs anywhere on PE or TB websites, so I didn't expect that. It's a nice touch in this price-range! This is apparently a difference from the -SA version I also have. I doubt you can see it in this picture....
    I'm going to try for about 500 Hz for the xover point above this W8 unit.
    The very tiny 13-1761S does not have polarity markings, so I'll have to investigate that and report my findings. It is VERY tiny!!!! It has a threaded hole on the rear for mounting should you want to use it, and reportedly works best above 8 kHz, 12dB elec.
    The W3-1335SB is just a rarely used jewel I hope. Same kinda clarity from the midrange if it works out well, but limited on Xmax and output potential. I'll have to see how this goes.....
    Wish me luck! I don't know when I'll start on the wood, as I have too many project-irons in the fire.
    More on the 13-1761S tweeters...
    I stand corrected on my statement of no markings for this driver. They don't appear to at first glance, and I brushed it off. There is a dark-red paint-marker or even felt-tip marker designation on the opposing side of the screw-mount, on the half that is positive. I did a battery test to verify it, and while movement was small, it was visually noticeable.
    The terminal that is positive is on the right when both are positioned at 12:00 on the rear.
    Now- to soldering these tiny things. I had to attach leads to even get measurements, and used a stranded #22 or thereabouts as the solder-bumps are not large. Having a 'helping-hand' to hold the units might be beneficial while attaching the leads so it does not *move* on you. You may also have to add solder to the bumps before soldering to the leads so you have enough solder present for ease of attachment. I also recommend solder tipping the wire before hand. That was a smart move.
    As to the threaded insert, I'm not certain on size yet. It's about an 8-32, but it doesn't keep threading. The mounting screw is not included.
    Here's the Z-plots...
    Looks like ~4.8 kHz Fs on one of them.
      More info on the W8-1363SB's...
      These are very similar to each other. Z = ~120 ohms at 20 kHz, since I did not provide a plot.
      I did loosen the suspensions by hand until the break-in 'spider-creak' stops, as usual. I can provide .zma's if someone's interested.
        Re: Got my "Athos" drivers today.....
        Looks like a sweet project wolf, I've wanted to mess around with that 1/2" tweeter myself for a while now. You could carve a little notch out of the ND28 flange to get the 1/2" tweet as close as possible - when crossing up around 10khz i assume even 1/2" of closer spacing would help improve directivity.
          Re: More on the 13-1761S tweeters...
          Wow.. they are tiny. For coaxial use, originally?
          The screw's gotta be a metric thread, I forget which size is about that size...
          Curious as to how the new W8 measures out against the old W8's...
            Are you somehow reading my mind???
            The ND28F has a removeable face, and it's plastic. I can therefore do exactly as you have entertained. Probably with the midrange on the other side as well.
            We think alike, you and I!
              They are marketed as both co-axial and stand-alone units in a micro size.
              You can go to my PE Blog and read the "Compellurgy 8" project writeup for the specs on the W8-1363SA, which I also have.
              So I guess I have answered that question for you....
                You youngsters can hear that.
                  Wolf,
                  have you done anything with those Extremis yet?
                  Website
                    Re: More info on the W8-1363SB's...
                    I think those will benefit from a lot more break-in. My well broken-in pair measure 29.5hz and 30hz Fs with large signal.
                    "Looks like you may have to design your own speakers. Its not that hard." -DE Focht
                    Diffraction Happens
                      Originally posted by gowa View Post
                      Wolf,
                      That's on the horizon as well....
                      RS28, proto-Dayton Honeycombs (I call them the HS-180), and the Extremis in a 2.5 way. You can't buy either woofer, so I figured they mated well. (I don't know what I'm doing with the North's yet.....)
                      I actually have baffles for the 2-way portion, but I have to enlarge the cutout for the woofer. The Extremis fits in it, so I don't know if I'm going to enlarge the cutout, or just make an extension above to house the other woofer. It's up in the air at this point.
                        I suppose that's possible, Maynard!
                        Didn't occur to me, you old-timer, you! :rolleyes:;)
                          You usually don't get much variation, but I will be trying that in the near future.
                            Been doing some modelling....
                            I'm not revealing the parts for the xover at this stage, as it's not fair to exclude the woofer and provide a network. However, I will give the simulation progression a position in this thread for those interested. All sims are edge-to-edge spacing, without altering the ND28's flange for simplicity's sake.
                            ND28F-6/13-1761S;
                            BW4 @ 8740, and has 6 parts currently present; all small in value. No cap over 4uF, and no coil over 0.2mH. One ohm resistor on the ST. The off-axis plot is virtually unchanged out to 40 degrees horizontal. Vertical dispersion isn't horrible, but you lose about 1-2dB in the 12 kHz range at 20 deg:
                            W3-1335SB/ND28F-6/13-1761S;
                            Mid to tweeter is LR2 @ 2870 currently, and 3 parts per leg. I don't know how much bandpass gain is going to be a factor for the W3 once I get the woofer into play. W3 is in about 2 ltrs sealed. T and ST are reverse-polarity from the midrange.
                            Once I get an FR plot for the woofer (I don't trust TB's published plot for this), I should be a go on further progression.
                            TBD xover is going to attempt 400-600 Hz range for woofer to mid, and hopefully FR will be 25 Hz-beyond 20 kHz with very good off-axis responses, net sensitivity of 85dB or so, and relatively low parts count. I'm trying to make this a mostly 12dB electrical xover like the predecessor "Icthus".
                            Thanks for looking!
                              The screw that works is an M4. I will probably mount it to a piece of hardboard on the rear of the baffle, and notch out for the lead wires like a keyhole. This way the screw still mounts and holds tight, and the terminals don't get all mashed or damaged.
                              I'm toying with a removable 'plate' to mount the upper 3-way and simplify installation in the smaller chamber. I don't think I want the whole xover outside the smaller chamber, so that means it's inside the smaller chamber, and the woofer's outside in the main volume. I only have to seal 2 wire holes this way, and not additionally cram them through a 2.5" hole. I know I could have done that, but it's never easy!
