Further pondering....
I currently have (on-hand) these drivers for the upper-3, as well as the W8-1363 woofers:
I have not solidified this project at all yet, but I've thought more about a few things...
1-Curt's 'Mavericks' at Iowa made me think twice about considering this little gem for the midrange:
The 4 ohm mid impedance might play havoc with the 4 ohm bass impedance, more on that below...
I could even place the dualing mids side-by-side and switch-out the unit with their relating xover network for demonstration purposes.
2-As well as possibly considering a TL for the bass alignment with the W8-1363SB 8" driver.
3- What if I used the W6-1139 and the W8-1363SB in series, with the 1139 in a sealed box and the 1363 in a TL (if it will model well in a TL, and I need more break-in on the drivers to even begin to verify that...)??
The integration for the mid to 1139 would be just as good as it was in the Icthus I wager, whichever midrange I use due to the wavelength and diameters at task. I'm also betting a sealed box for the 1139 would roll it off early acoustically, and allow the 1363 to take the majority of output down low. All of this of course running in tandem allows for less Xmax on either bass driver.
The reasoning for the sealed/TL tandem idea, is that I cannot run the units in parallel being they are 4 ohms each. Therefore, I cannot do this as a full 5-way or true 4.5 way. It would have to be amped separately or use in series.
Problems inherent are individual bass responses running at once, and I would hopefully be able to incorporate them separately for simulation, and passively at the same time in the end. I don't want to hinder the lowend response with a plate amp's filtration, as I know they will do a lot of nasty (:D) things down low unhindered.
4-Another thought for possibility, is porting the 1139 internally into the chamber for the 1363, and sort-of DCR'ing it for more control.
So- Athos might be getting a slight revamp in the final look. Not that I won't try to simulate the W3-1335S as well if I opt for the different mid....
and 5- Wouldn't that just look really cool in person!!!?? 5 drivers of increasing size in a cohesive sounding very dynamic speaker...
Concerns, opinions, +/-?
