I recently purchased a definitive technology.D1LW subwoofer that was used in their bp 3000 tl 18 ht system.This was supposedly able to go as low as 13 hz. I have plans for a tuned port box where it is able to go to 10 hz. To me this would be perfect for ht. Now my question is why you dont see 18' used for this. Is it that they cost too much. Or is a matter of size.Is too big an amp needed?
18 in subwoofer for ht. pro or con
Re: 18 in subwoofer for ht. pro or con
Do you have the T/S for this sub?
as for people not using 18" drivers too often for HT use. I haven't seen many posts here, but over at HT guide that's about all people seem to use. Mind you these people have large rooms just for HT use.
ReneIf it doesn't fit, Force it. If it breaks, It needed replacing any ways
I had to use the wall behind my couch for an IB install of the dayton rss390hf-4 > I need 3 inches of mdf to make the baffle deep enough that the sub did not stick out in the bedroom behind the HT room. Would have been nice to use an 18 but was not going to happen. I run the IB from 18hz to 50hz so an 18inch IB running from 10 hz to 50hz would have been nice!
Kevin Haskins of Exodus Audio/DIY Cable is just about to relase a 21" version of his very popular Maelstrom-X subwoofer driver. There are quite a few 18" builds over on AVS as well. Most powered with at least 1500 watts. There are lot of Maelstrom-X builds and a fair number of people who were lucky enough to get the TC Sounds/Audiopulse 18" LMS-5400. Which by the way, a new and improved version of the LMS 18" should be back on the market in about 6 months.
Regards,
Dennis
Originally posted by djarchow View PostKevin Haskins of Exodus Audio/DIY Cable is just about to relase a 21" version of his very popular Maelstrom-X subwoofer driver. There are quite a few 18" builds over on AVS as well. Most powered with at least 1500 watts. There are lot of Maelstrom-X builds and a fair number of people who were lucky enough to get the TC Sounds/Audiopulse 18" LMS-5400. Which by the way, a new and improved version of the LMS 18" should be back on the market in about 6 months.
Regards,
Dennis
NKI'm just that guy. www.sru.edu Rock Solid.
"It has been remarked that if one selects his own components, builds his own enclosure, and is convinced he has made a wise choice of design, then his own loudspeaker sounds better to him than does anyone else's loudspeaker. In this case, the frequency response of the loudspeaker seems to play only a minor part in forming a person's opinion."
L.L. Beranek, Acoustics (McGraw-Hill, New York, 1954), p.208.
I would assume the reason you don't see much larger than 15" in HT is that they typically require very large boxes. That and there aren't really that many 18" HT subs available... and the ones that are tend to be quite expensive. And beyond that, unless you have a huge room, 18" drivers normally aren't necessary. A single high quality 12"-15" driver fed with adequate power should be enough to shake most any room (of course, multiple subs are always good for evening room response).
Pro sound normally uses 15" and 18" subs because they need high SPL (and high efficiency) for large venues or outdoor use.
Rene
Whether or not this is a reasonable option will depend on the T/S parameters. Are there any photos of the driver itself? What was the intended use of the driver? Was it intended for PA use?
It may be a very good option or possibly a very poor one. I will not purchase a driver without T/S parameters as it leaves too much unknown.
As for 18" drivers the Exodus Audio 18" Maelstrom-x is a very linear unit that works well in many applications.
Originally posted by Jason View PostI would assume the reason you don't see much larger than 15" in HT is that they typically require very large boxes. That and there aren't really that many 18" HT subs available... and the ones that are tend to be quite expensive. And beyond that, unless you have a huge room, 18" drivers normally aren't necessary. A single high quality 12"-15" driver fed with adequate power should be enough to shake most any room (of course, multiple subs are always good for evening room response).
