Finally decided on jkim's "Poor Man's High End Monitors" (yes, really, parts have been ordered :p). These are for my best friend's 40th birthday. Intended for music, to be run full range, unless he decides to add a sub.
First things first: Big thanks to jkim for all his help on this, his work on generating this design, and all his contributions to the DIY community.
More info on the Poor Mans here: http://techtalk.parts-express.com/sh...d.php?t=207805
Volume is .8 cubic feet, vented (volume accounts for braces). Baffles are tipped back at a 5 degree angle. All 3/4" mdf, painted, color TBD (blue is very likely). Small PE spikes on the bottom. 5/8" roundovers on the vertical corners.
Baffles and braces will be CNC'd, since they are too big to fit on the rotary table here at work, I hate plunge routers, I have a friend who will give me a great deal, and mdf dust is no fun... plus I'm lazy.
Ports will be PVC pipe, exact port dimensions TBD. Walls will be lined with 1" rigid fiberglass. Region below lowest brace will be stuffed. Driver geometry in illustrations is approximated.
Crossover will be mounted to the base, and accessible by unscrewing the base. Note the lugs attached to the side walls that will accept screws for attaching the base.
Crossover design will be kept confidential until jkim decides if and when to publish the design himself. Crossover shown is obviously approximated, and does not represent any particular components or even a part count.
Much more to follow of course... Any comments are greatly appreciated. Thanks!
Vifa DQ25SC16-04 1" Titanium Dome Tweeter
SB Acoustics SB17NRXC35-8 6" Woofer
EDIT: Updated design... taller, rear panel now leans back 4 degrees (was vertical)
