Hello to all... this is my first post so I'll try to not ask too many questions.
I want to build a 3-way speaker that sounds great, but can also play really loud. I am going to use the the Eminence ASD 1001 for the high, Eminence Alpha 6a for the mid and I think I've decided on the Dayton 12" RSS315HF8 for the woofer. I can't find any pro woofers that that can go that low without being 15"+ and needing the worlds largest box; plus the Dayton RSS315's have received great reviews. I would like to build a simple 6db 3-way crossover for all drivers, but use an 18db slope in the tweeter.
Questions:
1) I know I will need L pads on the Mid and Tweeter... will the L pad Resistors change the values needed for the crossover points I choose? I've read they don't.
2) Should I use a Zobel Network for the woofer (and mid-range?) I hear they help but am worried after I add Zobels and L-pads, nothing will work as I plan it too.
3) Because I'm using L-pads on the Mid and High, do I have to worry about whether I wire and the speakers in parallel. Almost every 6db and 18db crossover diagram shows all speakers in parallel.
4)Has anyone had any real experience using a 6db crossover with any of these drivers? I would plan on using crossover points somewhere around 450 and 4K Hz.
Thanks for you help
Questions:
Thanks for you help
