DIY Iowa Designs Posted?
  • DIY Iowa Designs Posted?
    Hi Guys,
    I was not able to attend this year and missed all the great fun that I have had the past five years. From what has been posted the event appears to have been another success. I am wondering if all of the designs will be posted somewhere. For those of use who follow the threads there are some available already but many have not been posted or I have not seen them. So the $2 dollar question is will all designs be collected and posted? I am really intrested is some of them as I am sure others are.
    Doug, thank you again for your efforts. Thank you for all who have worked to pull this event together.
    Kind regards,
    Eric Koeppen
    Re: DIY Iowa Designs Posted?
    I don't think that happened last year. Some guys had handouts and others have blogs and Photobucket sites that are well known. I have neither so I'll just say that most of my info for the Thunderstiks can be found in my project album:
    http://techtalk.parts-express.com/album.php?albumid=150
    or in this thread:
    http://techtalk.parts-express.com/sh...d.php?t=208723
    I'd be glad to answer any questions not answered there. One suggestion I've picked up since Saturday is to lighten up on the series resistor on the high pass circuit (Thanks Wolf!). I'll be putting that tweak to the test sometime soon.
      or in this thread:
      May want to add a Jeff B trick to the tweeter as well, and that would be to bypass the input padding resistor by a cap of a few uF, maybe 4uF. That'll lift the top octave just a bit.
        I should be able to try that, and I'll see if I can browse around for some examples. Thanks again Pete.
          To give credit where credit is due, I brought the Cryolites by LouC. The design is posted here (well established and reviewed design)
          My implementation was in a 21 L tower cabinet (made by Dave Ellis as defined here). I did the cutting, finishing, and added some bases and this is the result:
          The only other change that I made from original is that I used Erse parts in the crossover. Values are as designed. I cannot say whether these sounded better than Lou's version of the crossover or not, but the Erse products did save about $35 in crossover components. :D
          In the end, I was very happy with the result. I liked the cabinet construction which yielded a nice dead cabinet, with a svelte profile and a small footprint. The Cryolite design was one of the best RS180 TM designs I have heard and bests the Modula MT in the imaging category (very similar in bass).
            or in this thread:
            Turn2,
            I really like the looks of that design and would like to build it in the future. I'm curious about the tweeter section of the crossover. It looks like the resistor (2.7 ohm) is in front of the high pass circuit. Is that common, I thought an L-pad went after the tweeter circuit? I'm new to crossovers, though!
            That's a nice design, and the shape with the slightly angled front really appeals to me.
            TomZ
              Turn2,
              TomZ
              Pete Schumacher designed that crossover. I can't give you the technical breakdown on that methodology vs. what you would call a traditional l-pad. It is quite common, however. Here are a couple other examples that use the same technique, one by Wolf and the other I forget.
                I used the crossover designed by Jay Kim in my entry, the HDV-3. I played a bit with the values in the HP and I ended up at 6.6 ohm and 7.5 uF for the event, but may pad the tweeter more for use in my somewhat bright room here at home.
                I eventually ended up with an 8.5L box tuned to about 55Hz, but it took me while to arrive at that. The double thickness side walls sure didn't hurt anything! For those of you who bought a case of these and have not seen this thread, here are a few options for you to ponder...all thanks to Jay.
                http://techtalk.parts-express.com/sh...d.php?t=211207
                  Here's a link to a writeup on my Marcatos, graciously provided by Jeff Bagby.
                  http://www.box.net/shared/39uey2h19l
                  Paul
                    I get an error that "the user is not allowed to post direct links"--download won't start... tried in both FF and IE in case that would make a difference...
                      If you're referring to the link I included, I don't understand why it won't work for you. It certainly worked for me just before I started this reply and I'm sure many posts on this forum have included direct links that worked. In fact, I included that same direct link in a post back in April which many, many people used successfully.
                      Paul
                        Great post GBTBT, I herd of people doing this but was confused by what they meant when they said that they using the 3M product.
                        So I guess U will end up with a solid mount with this procedure.
                        _______________________________________
                        Website I designed for pay day loans ontario company.
                          Worked for me in Safari ....
                          Matt
                          Failure is not an option. It comes bundled with Windows.
                          We are passionate about great sound at whatever level we can afford, so don't let the audio atheists reduce the experience to a set of numbers and squiggly lines. - jbruner
                            Most sites are so poorly written for error handling nowadays, you may not get an accurate message--so I always suspect a cookie issue, since by default I have my settings turned off to accept cookies. Once I turned on cookies, the download worked...
                              Here's what I have for the Arpeggios:
                              http://files.me.com/labradork/4gvno9
                              Use at will. File under easy listening.
                              shawn
                              My favorite woofer is a Labrador retriever.
