If you have an immediate customer service issue, please visit us at Parts Express
Fun with TPS reports - Speaker selection decision tree
Maybe this will be helpful for someone. Use this to help make decisions when building speakers. I plan to make a few other flowcharts in the coming days for other topics such as modeling/simming/measuring.
Re: Fun with TPS reports - Speaker selection decision tree
Your "???" would be a design with very limited maximum output, or an extremely resonant character, and would likely be energized by a small driver. Transient response would be close to nonexistent. I think bandpass enclosures in general and the Bose Acoustimass 8th-order bandpass bass module in particular fall into this category as well. Small size, high efficiency, and low extension are goals in the pro audio world, and since the Bose patent on the 6th-order bandpass enclosure has been allowed to expire, the uptake of the design in the pro audio world has been rapid (see Mackie, KV2 Audio, RCF, FBT, Funktion-One, Void, and Community's new VLF line).
I'm planning on working with Wolf to design a Mass-Loaded Tapped Horn subwoofer to go with his Mr. East project (which I originally misidentified on several occasions as the "Mr. E's" until Wolf set me straight, but it seemed appropriate -- what are they? It's a mystery.) Mass-loading of a tapped horn enables shaping of the low-end response, but the tradeoff is a more resonant character as a high acoustic impedance is introduced at the end of the horn line. Other tradeoffs include higher driver excursion requirements and lower sensitivity further up in the passband.
While that does have some direction, it doesn't cover nearly all of the bases. There are many other options not inherent in that flowchart.
For instance, the bottom left with a lo-fi large no-bass system, it can be a hi-fi one, and just add a sub if required.
It's really kinda confusing, really.
"Wolf, you shall now be known as "King of the Zip ties." -Pete00t "Wolf and speakers equivalent to Picasso and 'Blue'" -dantheman "He is a true ambassador for this forum and speaker DIY in general." -Ed Froste "We're all in this together, so keep your stick on the ice!" - Red Green aka Steve Smith
I am sure that you understand that it is impossible to group the speaker designs along multiple axis'. With that said I chose cabinet size, bass extension and efficiency. I am open to suggestions on how this can be best accomplished.
I had a hard time on some of the choices, since the items could fall into multiple categories. I also had to draw a line on what I considered to be small vs large cabinet size... I chose 1ft3 as the mark of delineation. I stuck open baffle into the large size... Bass extensions is another rather subjective terms since a 6th order at 50hz likely has less bass than a 2nd order at 70hz...
I went through and re-labeled some of the systems at the bottom.You may need to refresh your browser.
Take it easy on me since I am doing this in my free time. To my knowledge, no one has ever done this before, visually.
It is a good visual aid, don't get me wrong.
Kinda reminds me of the '3-option triangle' for woofers.
-small box
-deep bass
-high sensitivity
Just you can only pick 2!
PS- I also do this in my free time!:D
maybe you just need a bigger tree.
I think my tree covers all of the same features as the driver performance triangle. In fact, it adds the driver choices as well. Are there features missing that you are looking for? Perhaps one could explore efficiency -- damping vs resonant as the 4th dimension.
Does anyone have any creative data presentation techniques that would allow the 4th dimension to be displayed?
Yes- it does, and there is more there. But it did remind me of the triangle...
4th dimension- Isn't that before they got a fifth guy in the group? ;)
