Anyone ever try Minwax Wood Hardener to seal mdf?
Re: Anyone ever try Minwax Wood Hardener to seal mdf?
Dan, I think there was a thread on the HT form, that talked about this product.Ed
___________________________________________
If "IFs" and "BUTs" were candy and nuts, everyday would be Christmas!
_____________________________________________
My WebSite
Originally posted by lunchmoney View Post
Dave
http://picasaweb.google.com/pelegrn/TheNightmares#
Ditto to Dave's post. The cabs I built per Wolf's specs for the indy 2008 show did the same thing. Every staple and joint are visable with the sealer inside and out and 3 coats of high build primer and 4 coats of house of colors auto paint + 2 coats of top coat. $75 worth of auto paint f$%#*d up due to the sealer. Did I mention I sanded between all coats. Its like it never dries out and swells the surface of the substraight. Look at them one day and you cant see a seam come back the next day and there all swelled up. Only to dry out a little and swell up again like a bad x-girlfriend.
Aaron
The thread over at HTGUIDE had a great discussion over how to make your own hardener. For all that hate the swelling of mdf, I'm not sure hardener will fix it. I still stick to my guns on using undiluted wood glue across both the inside and outside surfaces.... After that, allow the material to marinate in a controlled humidity environment for a few weeks...
Originally posted by brianpowers27 View PostThe thread over at HTGUIDE had a great discussion over how to make your own hardener. For all that hate the swelling of mdf, I'm not sure hardener will fix it. I still stick to my guns on using undiluted wood glue across both the inside and outside surfaces.... After that, allow the material to marinate in a controlled humidity environment for a few weeks...
Brian, what kind of wood glue are you using undiluted?
Today I tried Elmer's wood glue undiluted to seal my "Poor Man's", and it was much too thick to spread into a nice thin, even coat... I ended up diluting it 2/1 (glue/water) and even that was just barely thin enough...
I'll go back to 60/40 on my next project... unless you know of a thinner wood glue.
The hardener seemed to make it harder... than Shellac or other things in that test. Not sure if the water penetration would be different, or something else would win out or not. Stuff is pretty expensive.
With all these folks "sealing" their boxes and still having dimensional shift, I wonder how many are actually sealing the inside as well as the outside? I imagine if you don't cover pretty much every square inch, you eventually might have problems.
Only problem with the thicker glue/water would be how uneven it may end up, and more sanding to level the surface. Well, that and the basic thing of when you use glue and water, you're adding WATER to your MDF, which then will need to distribute, and outgas over time. I still think shellac with it's ethyl alcohol base might impact less and evaporate faster. But, haven't done any comparisons that would be true experiments.
Originally posted by lunchmoney View PostBrian, what kind of wood glue are you using undiluted?
FWIW: I have pretty much stopped using MDF due to the laborious nature of the process.
Originally posted by lunchmoney View PostYeah, the only thing that keeps me using it is the low cost.
0. Seal insides of box
1. Build box
2. Bring inside and let sit for 2 weeks in a controlled temp/humidity environment with air flow.
3. Flush trim
4. Seal box
5. Let sit 2 more weeks
6. Sand and finish
I am finding that Regular 3/4" birch plywood is not too much more expensive and is much less labor intensive. I probably pay $40 for the sheet vs $24 for the mdf. The finishing materials really aren't too much more expensive than paint. In fact, they may be cheaper.
I have a friend who has a big oven at his shop... he's going to be building mdf speakers soon, and intends to bake the panels prior to gluing up, and then bake again after gluing and sealing. If that doesn't work, I don't know what will.
I think the bigger question is: do you really care if the seams emerge a tiny fraction of a millimeter?
I was quite annoyed when I first noticed it, but I no longer care. The speakers still look fantastic, and you can only tell from less than a foot away.
I would be careful putting watered down glue on MDF in large amounts. It is WATER, the nemise of MDF. Use something with a solvent based thinner, like shellac, woodhardner or the clear SANDING SEALER from Minwax; for sealing purposes.
I seal the edges of my baffles with PVA glue but this is a lot more water!!
Originally posted by lunchmoney View PostI have a friend who has a big oven at his shop... he's going to be building mdf speakers soon, and intends to bake the panels prior to gluing up, and then bake again after gluing and sealing. If that doesn't work, I don't know what will.
Has anyone used latex paint? I wonder if it has enough flexibility not to show through.
