Anyone ever try Minwax Wood Hardener to seal mdf?
  • MagicO309d
    Re: Anyone ever try Minwax Wood Hardener to seal mdf?
    I've had glue seam bulge with BB ply built cabinets too. Maybe the solution is to find a glue that's much harder/more stabile than Titebond or epoxy?
  • jerrald
    Has anyone tried DAP DryDex drywall spackling?
  • David Crewe
  • donparsons
    Originally posted by lunchmoney View Post
    I like roundovers... not much point in miters if you're just going to roundover the edges.
    fair enough...
  • lunchmoney
    Originally posted by donparsons View Post
    As good as your woodworking skills are, why not do 45 degree miter joints and avoid having end grain at all?
  • donparsons
    Brian, I have to say that overall the 2:1 mixture of Elmer's wood glue to water was terrible.
    Too thick to spread into a nice even coat, and a real pain to sand... lots of hardened "drip" shapes.
    I made do though.
    I can't imagine how you were able to use undiluted and get a smooth finish
    Definitely going back to a 60:40 ratio next time.
  • lunchmoney
    Originally posted by davepellegrene View Post
    I think it is controlled test time.
    I am going to make up some right angle test pieces and glue them up with Tite Bond II. Then seal them on all sides.
    So far I have;
    Yellow wood glue, mixed 60/40. Is the 60 water? Does it matter which type.
    Shellac, I have the Bin 123 white pigmented shellac.
    Fiberglass resin, I have some of this also.
    Are there any other methods that I should try.
    I am going to take a piece of MDF from my shop, unheated.
    I will also out of the same piece heat some in the oven and keep them inside.
    Any other thoughts?
    I think with the time and money people are investing in speakers it would be a good idea to try to come up with the best methods possible.
    I will start a thread on it when I get started.
    Dave
    "60" is glue
    Great idea on this. Make sure you follow up with a report 6 months and a year later.
  • davepellegrene
    So far I have;
    Any other thoughts?
    Dave
  • rtkelly
    Greetings;
    Have any of you guys tried MDO plywood? I have some porch speakers cut out but, I haven't assembled them yet. It appears to be sturdy enough, sometimes used for concrete forms, I just don't know how stable it is. If no one has any experience with this material, I will post what experiences I have with it as I progress. TIA.
    Rollie
  • lunchmoney
    I made do though.
  • davepellegrene
    Originally posted by bobhowell View Post
    Here you are drying it out before finishing. So, little movement after finishing. De-waxed shellac holds out moisture better from my readings. Also, other finishes adhere better. At best, finishes slow moisture transfer, not stop it. I have never read just what that means thought. Keep the speakers in an air conditioned/heated room and you will miss the extremes that tear them apart.
    I have used diluted white pigmented shellac on four speaker builds inside and out. Then sprayed with automotive paint over top. They eventually showed seams. I think over time the MDF draws moisture and expands. Doesn't take much to show a seam on high gloss paint. At my link below has pics of all my builds except two subs. The Nightmare set I sealed with the Minwax hardener, then let them sit inside for a month, then primed with shellac, then waited a month, then painted. Still showed some small seams that were not visible through the time they sat.
    Dave
  • bobhowell
    Originally posted by waynew View Post
    Aaron Hero had a nice process on how to make MDF not show seams, and it involved using a Halogen light as a heat source and an old vacuum motor to push air inside his cabinets to dry them out. Personally, I have found that the only way to not get seams that show is to use a high build primer, and wait it out. Once the seams show up, then sand and put another coat on. This can take a couple of weeks, so patience is the the name of the game. After that, you play the same game with the color coat. MDF is a bear!
    YMMV~!!!!!
    Wayne
  • davepellegrene
    Originally posted by gregrueff View Post
    I am in the process of finishing up a speaker doing just this.
    It is MDF, sealed with a dinky water based paint on the inside and covered on the outside in a blackened, twill weave fiberglass with polyester resin. It looks like carbon fiber and is pretty darn slick.
    But when I talk about this project in years, you will understand how tedious and stupid it has been. (There was considerable slacking involved too.)
    Although I am quite convinced it is the most solid, inert box I have ever and will ever build. The knock test reveals a very high frequency resonance. And the composite strength of the fiberglas and resin has convinced me no amount of moisture pickup is going to have enough force to deform the seams. Just compare the base modulus of MDF against polyester resin- before you even factor in the fiberglas contribution to the composite. Magnitudes of difference.
    I have just finished sanding the whole thing smooth with 60 grit. Now to spray on a nice high gloss finish. Once the whole thing is finished I intend to post pics with a full report.
    Greg
    That's basically how a boat's made. I bet that took a lot of work. Can't wait to see them. I plan on trying the resin method, when I do another painted cabinet.
    Dave
  • gregrueff
    I wonder if coating the speaker with fiberglass resin, like you are doing with the glue would work better. This might bridge the movement enough. The only thing I could see happening with enough expansion it could crack the resin.
    Greg
  • waynew
    YMMV~!!!!!
    Wayne
