That is all.
Nearfield measurements have no baffle losses, right?
Re: Nearfield measurements have no baffle losses, right?
If by "nearfield" you mean with the mic at the baffle surface, then yes. I haven't done any other close proximity measurements to otherwise comment, but it would be interesting to see how the response changes as you move away inch by inch.
I mean with the mic an inch from the cone.
I'm trying to figure out the best way to measure these TMWW towers. I had a previous thread here but I don't know if my measurement-fu is strong enough to intelligently go splicing nearfields and farfields and whatnot. I tried Curt's recommendation of measuring the woofers at 1m with a bunch of blankets and pillows on the floor to help damp some of the floor bounce but I still see a lot of ripple up as high as 700hz (see attached, blue = far, red = near). Since I think I need to cross below the point where ripple rears its head I'm looking at all my options.
If nearfield measurements do NOT include baffle losses, then I'm wondering if I can just import the FRD files into Jeff B's Response Modeler to add the losses and then go about my XO design.
Originally posted by Dirk View PostIf nearfield measurements do NOT include baffle losses, then I'm wondering if I can just import the FRD files into Jeff B's Response Modeler to add the losses and then go about my XO design.
Modeling the woofer in box low frequency response and diffraction effects using Jeff's nifty program would probably be the easiest, and likely the most accurate choice. -Although you will still want to splice in your far field measuements somewhere above the baffle step.
-Or you can simply smooth everything to 1 octave. :D Not very accurate, but boy does it look good!A process used by design professionals everywhere to get great looking plots....
CCurt's Speaker Design Works
"It is the mark of an educated mind to be able to entertain a thought without accepting it."
- Aristotle
Originally posted by billfitzmaurice View PostThere's two schools of thought there. The most popular is to measure them outdoors, then if you want to account for BSC etc. you'll have a speaker that's flat in half space. The only problem is that you don't listen to speakers in half space, and in room they'll be totally different. Option 2 is to measure in room with the mic at the average listening position and go from there, keeping in mind that severe narrow peaks and dips are boundary reflection sourced and shouldn't be considered for passive correction, that's better handled by DSP, if you bother at all.
If I'm merging nearfield and farfield, I need to at least get my farfield measurements BELOW the BSC corner correct? Because with a 10.5" baffle, that means I'd need to get farfield down to about 400hz or so and I'm seeing ripple effects almost an octave above that.
Originally posted by curt_c View Post-Or you can simply smooth everything to 1 octave. :D Not very accurate, but boy does it look good!A process used by design professionals everywhere to get great looking plots....
C
How did you measure the HDS in the Mavericks? Let me guess -- you didn't, and it was accomplished by touching the cone and achieving a zen-like state of true enlightenment. ;)
I measured it like I suggested previously: 1 meter on the woofer axis with a stack of foam on the floor. I just mentally attempt to 'remove' the residual floor bounce effects when I design the crossover, (The TLAR method in action!:D) and fine tune any irregularities when I voice it.
Yes, I'll admit that using this method I've had to substitute a different value inductor from time to time, and trim the odd mid and tweeter attenuation a bit. John's ground plane measurement suggestion is a good one, and would double the accurate low frequency response in a given room. Remember, all else being equal, subtract 6 dB from the ground plane measurement compared to the free standing ones.
- Aristotle
More argument for active electronics, I suppose: if one were to build a stationary "reference system", using DSP and active xovers would make it possible to - after averaging reflections and power response - actually get very near a linear response at the listening position.
I still adovocate speakers that can be moved around, and if my dollars weren't so tight, I WOULD be going active ... oh well, I'll stick with passive for now.I am trolling you.
Originally posted by MSaturn View PostMore argument for active electronics, I suppose: if one were to build a stationary "reference system", using DSP and active xovers would make it possible to - after averaging reflections and power response - actually get very near a linear response at the listening position.
-And of course, you can't equalize out a dip...
- Aristotle
Curt, I tried your "damped floor reflection" method but I don't know how much it helped. Then again, I didn't do the OBVIOUS thing and try it once without to see what happened. I'm usually a pretty methodical person when it comes to problem solving, but I fell down flat this one.
I didn't take anything down last night, so I'll try again once I get the kidlets in bed and find some way to get the dogs to stop running around upstairs... :rolleyes:
Originally posted by Dirk View PostCurt, I tried your "damped floor reflection" method but I don't know how much it helped. Then again, I didn't do the OBVIOUS thing and try it once without to see what happened. I'm usually a pretty methodical person when it comes to problem solving, but I fell down flat this one.
I use BDS to work out position of drivers on the baffle and attempt to mitigate potenital floor bounce issues.Dave
If you can read this, thank a teacher.
If you are reading it in English thank a Veteran.
SUCCESS!
I measured with a bare floor and then with a stack of dense pillows and corduroy blankets on the floor (I used a lot more dense stuff tonight than last night). The majority of the ugliness is gone.
The remaining difference between the 6ms gate and the 15ms gate is minimal. The 15ms gate has burps of +/- 2.5dB, but if you squint at the monitor it looks a lot like the 6ms measurement. There's a slight variation of *maybe* a dB at 300hz. Anything wrong with using the 6ms gate? I'll attach a screen shot in a bit.
I can now see why people do 2-ways with the 8" Silver Flute. Veeery smooth midrange.Last edited by Dirk; 11-23-2009, 11:16 PM.
Originally posted by Dirk View Post...and find some way to get the dogs to stop running around upstairs... :rolleyes:"...this is not a subwoofer" - Jeff Bagby ;)
