New build with pics...
  • #16
    Re: New build with pics...
    Originally posted by MrkCrwly View Post
    I too like the way you set the speaker proud. Gives a more finished look. Do you use the Jasper 200 jig for all of your speaker routing or do you also have the Jasper 400 for tweets?
    I always enjoy your build threads.
    Thanks
    Mark
    I only have the big one, which I had to shoehorn my Rigid palm router on. Some of the small holes are unusable due to the frame of the router being in the way. So on small holes I have to get creative.
    On a separate note, I used polyurethane glue for the first time on the small brace, and I think I prefer that to regular yellow glue. Longer setup time, which I like, plus since it expands just a bit, its gap filling! I am going to finish out this build with it.
    It seems like there aren't many people posting build threads these days. What gives? I think even if you build a design that's been done a thousand times, there is always something that someone else can learn from pics or the accompanying writeups.
    My projects
    https://picasaweb.google.com/112307725038877176664
    • #17
      I think it has to do with the really cold temperatures. I've been working outside a bit (it was 5 degrees F yesterday when I was routing), so progress is a little slow (I can't stay out there for long). Then I have to wait for the MDF to warm up so I can glue it. My basement is about 55 degrees F, so it's right at the lower limit for Titebond.
      I figure I'll start a build thread soon. My photo uploading site was hacked (none of my old build threads have photos any more), and now I have to get a new one.
      I agree with you...I love looking at build threads...but your shop it TOO CLEAN :D!!!
      Statements: "They usually kill the desire to build anything else."
      • #18
        The build threads are what go me to join this site. I will follow any build thread be it large or small, easy or complex. The ones with good pictures (such as yours) give a lot of good detail information without having to write a word. Such as laying out crossovers, routing cirlces, tools used, etc.
        There is so much valuable info discussed here that it is hard to assimilate everything. Shoot, just this week I learned that overpriced caps cause global warming.
        Mark
        Mark
        My TriTrix Build
        My Core 2 Way Build
        My RSS315HF-4 Subwoofer Build
        • #19
          I am a bit surprised that there aren't more DIY'ers that post comprehensive pictures and writeups. So many times I see a post by someone proud of their just finished speakers, and they have 2 pictures... from a cell phone!
          egad!
          Give back people!
          My projects
          • #20
            Lookin good!! Yeah, build documentarys are a great pass time ! I started mine and will post soon, but like others the weather put a hult to it....booooo!
            A mains
            The Ventures
            Open Invit8tions
            RSR
            Sound Troopers
            Acorns
            442
            DGBG's
            The Monuments
            • #21
              What an immaculate build so far. You take your time, and do it right. It really shows.
              Looking forward to more pics!
              • #22
                CK and Lunch do you guys just eyeball mounting screw position or do you have afancy way of measuring?
                DP
                • #23
                  I don't eyeball. I use an L-square and line up the upper or lower pair of screwholes in the driver with the driver inside the rebate. mark holes, remove driver, drill and check.
                  Oh- and as a visual point only, I don't like to cardinal-mount drivers. To me they look like they are actively balancing a tightrope underneath, and look unstable and might possibly tip-over. I always place 2 mounting holes under the woofer instead of one. I know that's odd, but if I can avoid cardinal-mounted drivers, I will. I've had screw-ups in a few builds long ago where I had to redrill and rotate the drivers, but that was a mistake.
                  • #24
                    I just eyeball a pleasing configuration, than use L-square to make sure the side screws are aligned vertically.
                    I'm with Wolf, I-shaped screw configuration looks, unbalanced.
                    My projects
                    • #25
                      Got a little more work done.
                      Have the enclosures glued up. Next up is routing the front back using flush bit.
                      I am planning to paint the baffle semi-gloss black, using a felt roller. Sides top and back will be veneered with maple, (Band-it brand from PE)
                      Inside shot.
                      Being that this is a sealed design, should not liberally applied glue be sufficient to seal? I have seen people use silicone sealant on the inside seams, but is that really necessary? I would be surprised if any air could get through those glued joints.
                      Maybe is more of a hope, as it will be a PAIN to apply sealant to the inside seams, since I have closed it up...
                      My projects
                      • #26
                        It's only for if you someday need to take them out or replace them... self-tapping screws don't like going into the same mdf holes more than once... usually you can get away with it, but... you seem my point.
                        If you drill a pilot hole before you set the screw, you can back a screw in and out of MDF 20 times without damage to the MDF, but you MUST drill a pilot first.
                        • #27
                          I agree with Pete, pilot holes are a must with MDF.
                          Website
                          • #28
                            feel your pain on lack of room for hurricane nuts. One thing you can do, especially for a tweeter where they aren't taking any stress is to bend up one side of the little flat plate (stick it in a vise and a few hammer taps suffice).
                            • #29
                              Inside shot.
                              You're fine. The places I find the most problems are the mounting holes for drivers and terminal plates. If you've applied glue liberally, as it looks like you have, I doubt any air is moving through any of your seams.
                              • #30
                                CK, those looking great so far! I will be interested to see how you finish the maple veneer and to get your impressions of the sound when they are finished. I have 4 of the woofers for the MTM version but have not pulled the trigger on the SB tweeters yet.
                                Oh...and I wish my table saw was that nice & shiny. Mine didn't look that good even when it was new!!
                                Tom
