In theory, if you are using a woofer below 500 Hz, is there any advantages/disadvantages to a larger/smaller dustcap?
Dustcaps and Woofers
Re: Dustcaps and Woofers
Originally posted by vanapplebomb View PostIn theory, if you are using a woofer below 500 Hz, is there any advantages/disadvantages to a larger/smaller dustcap?
If you have a somewhat flexible cone, such as a polypropylene cone, can a dust cap about 2/3 the cone diameter substantialy increase the stiffness of the cone?... say an 8" woofer with a 6" diaphragm, with a 4" dust cap?
I notice B&W has a similar theory with there "mushroom" dust caps.Last edited by vanapplebomb; 01-12-2010, 07:10 PM.
Originally posted by vanapplebomb View PostIf you have a somewhat flexible cone, such as a polypropylene cone, can a dust cap about 2/3 the cone diameter substantial increase the stiffness of the cone?... say an 8" woofer with a 6" diaphragm, with a 4" dust cap?
Originally posted by vanapplebomb View PostHow much of a gain would you get?...enough to hear an audibly tighter bass in the lower regions?
Hey, but if you think you will, go for it and learn by doing.
Sorry, i Think i had something else in mind related to the effects of cone break up modes.
B&W's acclaimed mushroom bass driver is full of baloney? another marketing schema? I would think that a company of that kinda caliber would have a solid reason for every little detail of there products.
on the other hand, i should think that a solid cone should be beneficial to sound quality!
I believe Vance Dickason refers to this type of cone brake up as "Concentric Cone Modes" if that helps anyone see what i'm talking about. It would seam logical that one who specializes in driver design would take the dust cap into serious consideration. If you can eliminate some of the concentric cone break up modes, then it would be only logical that your subjective sound quality would rise due to lower distortion due to cone resonance break ups.
I'm not trying to come across harshly or anything,
The size and rigidity of the dust cap can affect the high frequency response of the cone it is attached to. A solid-composition dust cap provides annular stiffening at the point of attachment, and that is probably the effect that most driver designers are going for when they use large dust caps, but a large dust cap also causes diminished high frequency response, due to a phenomenon called doubling and its interaction with the space underneath the dust cap. As the cone is driven at frequencies above its pistonic range, it still radiates pistonically over smaller and smaller areas with increasing frequency, and once this pistonic radiation area fits completely inside the dustcap's diameter, the energy is radiated into the cavity under the dust cap and the amount of energy radiated into the room diminishes because of the non-pistonic motion of the exposed radiating area. The space under the dust cap essentially acts like an acoustic bandpass filter, vented through the pole piece vent. This seems like it could be used to cause a steeper upper-midrange rolloff, but it's also why many full-range drivers eschew the dust cap entirely and use phase plugs. The driver essentially becomes a ring radiator at high frequencies.Best Regards,
Rory Buszka
Taterworks Audio
Originally posted by vanapplebomb View PostIf you can eliminate some of the concentric cone break up modes, then it would be only logical that your subjective sound quality would rise due to lower distortion due to cone resonance break ups.
Hmmm....
so, lets suppose an individual has a XO phobia....
If they wished, they could then design drivers with the proper inductance and dust cap size to have a specific natural high end role off. Then they could just put a blocking cap in series with the next driver to provide it with a high pass...
just ideas that are going through my head...
There are those who insist that the benefits of 1st order electrical filtering outweigh the problems raised by not having at least 3rd order total slope. I'm not one of them, but to each their own.
