Help a newbie!
  • Help a newbie!
    I just need a little help to identify which of the terminal is the positive on a TangBand 25-1166SJ
    The smaller or the larger one?
    TIA
    Re: Help a newbie!
    should be the larger one. use a 9volt battery pos to pos should make the go out.
      Re: Help a newbie!
      Anyone else?
        Re: Help a newbie!
        DO NOT use a 9V battery on a tweeter, or any driver. Unless you think buying a new one is worth finding out which terminal is positive.
        "I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
          Re: Help a newbie!
          I typically use a AAA, but Alan (AE) assures me a 9V won't hurt due to the short time-span the battery can produce the voltage through the driver.
          I have the 25-1414, and the larger is the positive.
            Re: Help a newbie!
            Correct me if I am wrong, but in my experience, the smaller one is always negative.
            My projects
            https://picasaweb.google.com/112307725038877176664
              Re: Help a newbie!
              Not always.
              Audax used to have 'positive-small' configurations, so it really depends on the drivers/manufacturers.
                Re: Help a newbie!
                On every Tang Band driver I've ever used the Positive terminal was identified by a small drop of paint, usually dark blue or red. IIRC it's always on the larger terminal as well.
                I veified this via a TB Tweeter and mid-woofer, so i'm fairly comfortable with this ;)
                One other thought, Wolf is a natural born contrarian. If there's a slight chance of something being other that the standard he'll reference it for ya! Ain't that right Wolfie!!
                  Re: Help a newbie!
                  There is a little yellow spot on the larger terminal. I wasn't sure if it were corrosion or paint. And I'm color blind, had to ask the wife...
