Originally posted by Deward Hastings
View Post
I was inspired to do this by building and listening to Jeff B's Dreydel. He sent me an option that uses the RS28 instead of the 27TDFC, and my thoughts naturally drifted to adding a substantial low end to it. I heard the Marcatos by Paul K in Iowa, and they were simply wow. That's the only reason I modeled with the Ushers first. While the woofer and tweeter are set, the mid isn't.
The RS180 might work, and the RS150 as well, but they'd most likely have to be the 4 Ohm version to reach the required sensitivity. The XO target above was achieved with only .8 Ohms of padding on the RS28 and none on the Usher. The RS180 is a couple dB less sensitive than the Usher. But, the RS180-4 will likely work, with just a touch of padding. Active is not an option on this build. I want this to be a traditional full range 3-way that can be driven with a 250W stereo amp and laugh. I modeled room effects for placement in my particular living room, and while peaks and nulls will be present, the fact that there are two distinct stereo sources for bass to below 20Hz should help smooth out room effects.
And active set up will happen one day . . . ;)
