Hello all:
Some of you may recognize me as the fella that started an SP10 build about 8 or 10 months ago. Since then I've bought a house and been fighting to keep my job (like all of us!). So, it never got done. It's time for a reboot.
I'm looking to do a build with high WAF. I originally was going to do a 1.4 cu ft slot ported build because I wanted to reuse my 250w PE plate amp. Ported didn't need as much power, and I could tune the low end.
The new plan is to sell the amp and old woofer (see classifieds section) to partially fund a larger amp with bass boost. With a bigger amp and boost, I can put the SP10 in a .7 cu ft enclosure. Much more acceptable to my better half.
Here are my questions:
Which amp: BASH 500 or Dayton 500? The BASH is cheaper but the Dayton has EQ, which I'll need to get more bottom end out of my sealed design. The BASH apparently can be modded to add bass boost. I'm not afraid to undertake that. Any thoughts?
How do I design with bass boost in mind? I used winisd to model the box, but what program can I use to add boost from the PE to see what the story will be with the new amp?
Also, if anyone else has ideas on how to attack the problem of a big small sub, please post up!!
Thank you all in advance for your help!
